Results 1 to 3 of 3
Thread: engine oils
    saboor73's Avatar
    Oct 2013
    10,545
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Default engine oils
    AOA I heard somewhere that there is a product that is used to clean engine from inside and mixed with engine oil with some ratio that I dont remember is it true then plz tell me its name and the ratio with which it mix with engine and which engine oil is ideal for this mixing thing
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    WASALAM
    brother what is your ride?
    you are talking about ENGINE FLUSH ? it is mixed with engine oil
    it is simply additive to engine oil for cleansing the engine deeply
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    if your ride is a bike it is not recommended , if its a car the ratio is mention on the product of engine flush
    for the process , perform under quality mechanic that knows the process
