Results 1 to 13 of 13
Like Tree3Likes
  • 1 Post By vickytulla
  • 1 Post By asjdsm
Thread: Qingni 100 gearbox in 70
    saboor73's Avatar
    Oct 2013
    10,549
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Default Qingni 100 gearbox in 70
    AOA i have heard of installing Qingni 100 gearbox in 70 for 5 speed transmition so I want to know that it increases speed or no and how much is the differnce
    IceCold's Avatar
    Aug 2006
    33
    610
    20 Post(s)
    Quote Originally Posted by saboor73 View Post
    AOA i have heard of installing Qingni 100 gearbox in 70 for 5 speed transmition so I want to know that is increases speed or no and how much is the differnce
    Not just the gear box but people also install its head on to 70 cc and it becomes 100 cc. But this is only possible in chonda's with 78cc displacement and not 72cc. Hope this helps
    saboor73's Avatar
    Oct 2013
    10,549
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    I want to know that if I
    1.install 124 head cylinder
    2.5gear qingpi gear box
    3.remove the mudguards as well as tappas
    4.cb 180 cab
    would i be able to clock 130km/h on my chonda 70
    saboor73's Avatar
    Oct 2013
    10,549
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    I want to know where i could find a 124 head cylinder for 70 my friend have 124 head cylinder on his 70 but it is installed in it since he bought the bike is doesn't know where to find one
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    Quote Originally Posted by IceCold View Post
    no brother, 72c or 78 cc both have a same Dye only Cylender Bore is different... yes you can alter a 72cc Honda CD70 as well...
    4.cb 180 cab
    1 - Yes You can INstall a 124cc cylender even 132 is also possible (seen my self)..
    2 - There is no room for 5gears, and who told you that qinqi has five gears ? there is some other stuff which is required from qinqi engine and is not related to gear box.. its more related to clutch and fly wheel.
    3 - removing tappa/mudguards will make bike more messy specially if raining or muddy road no gain in performance..
    4 - CB carb will not work it will choke the Plug.. CG125 carb will work it piston is 110cc or above..
    5 - No there are more alterations required to reach 130 and may be a bigger pistion then 124.
    From kabar market you can find it for as low as 500RS.
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    remember you cant reach even 100 with only Piston/Cylender change plus you can not install 100/107/109/124cc pistons alone and whole engine will have to be opened and crank along clutch will be replaced as well.. so to alteration you will need a whole doner engine or else it will be a failure..
    few pictures from alteration of my 70 ...
    Qingni 100 gearbox in 70 -1313502
    Qingni 100 gearbox in 70 -1313503
    Qingni 100 gearbox in 70 -1313504
    IceCold's Avatar
    Aug 2006
    33
    610
    20 Post(s)
    Quote Originally Posted by vickytulla View Post
    Ahh ic. I wanted to try this out on my Chonda 72cc road prince but the poster ( I forgot his nick) said that only 78cc can be altered and not 72cc. Thanks for correcting and updating me on this.
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    all can be altered but the easy altration without opening the crankcase is of 78cc cylinder labeled stock bikes..
    reason is that it has same stroke(cylinder lenght) as that of cd100,cd125, or 107/110cc class bikes.
    so its just top end swap at most..
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Hi buddies
    Has any one installed qingqi cylinder head and Piston ik stock 78cc chonda ? Are cage stud holes and the oil pump hole same?
    I am inclined in trying that on my chonda. Because qingqi says its compression ratio is 9.8 to 1. Awesome if is true.
    I already have genuine qingqi carb ad an aftermarket Silencer.
    I will be using stock timing chain and timing gear of chondas and also stock connecting rod. As stock chonda and qingqi has same stroke.
    Sent from my GT-I9300 using Tapatalk 2
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    Quote Originally Posted by asjdsm View Post
    Hi buddies
    no.. sadly ... clutch and gear box iiis same fitting but bigger
    Yes this is so true, but Qinqi ka saman new United 100 k sath sirf interchange hota hai bas ..
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    nahi yar @asjdm aesa hota tu mujhe saray engine ka operation na kerna perta ... maximum for 78cc chonda is 107 after that if you use 109,112,124cc Cylender the Weight is well Big enough in start it was not fitting as it was big then I had to get the center "pally" grinded and tolled by machinist to give spave to Hunge counter Crank weight let me find some picture of that..
    Qingni 100 gearbox in 70 -1317365
    Qingni 100 gearbox in 70 -1317366
    Jitni Pistons men Farak tha utna he Counter Wirght me bhi farak tha Look below the Wieght is almost completly filling the crank case .. not a silce room in it...
    Qingni 100 gearbox in 70 -1317367
    We found out cranck casde is not assembling as Crank was fatter the total area in crank case...
    Qingni 100 gearbox in 70 -1317368
    Sent it to Machnise he grinded and tooled after taking measurement of Crank and Counter weight and we finally got it assembled...
    Qingni 100 gearbox in 70 -1317369
    hope it helps.
  12. #12
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Vicky bro when you said no was that for the head cylinder swap?
    I thought that I would have no issue in putting a qingqi hear and cylinder on my 78 cc dhoom...
    What is it that is making this swap impossible.?
    Are the studd holes and oil pump hole in qingqi different then those of dhoom?
    I am already using qingqi 3 I plate clutch box in it along with qingqi clutch gears.
  13. #13
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    there are two type of qinqi 100 in market one with similar engine side covers of CD70 and one with totally different side cover.... and yes the one which has different side covers has differentoil pump veins and 78cc head fits on it but the hole is blocked.. instead of putting Qinqi use RoadPrince-100 head/Cylender that works on Chondas... men mashwara keron ga .. if I get more info then tell... old Qinqi engine design was not sucess when I asked to the mechnic he said ho;es block ho jatay hain ...
