Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By d3vil
Thread: The Most Powerful Electric Motorcycle In The World
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Cool The Most Powerful Electric Motorcycle In The World
    The Voxan Wattman was unveiled this week at the Paris Motor Show. The new electric motorcycle may even achieve the glory of being the most powerful of it?s kind. With a maximum output of 150 kW (200 hp) of power, the 350 kg bike is able to accelerate from 0 to 100 mph in just 5.9 seconds and is capable of a top speed of 106 mph.
    The Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 2
    The styling of the Wattman is based on the exoskeleton of a scorpion and the entire bike is built by hand only once an order is received. The 150 kW motor of the Voxan generates 200 Nm of torque at 10,500 rpm and requires no transmission since the torque is available over most of the torque curve. This means that no shifting of gears is required and the acceleration is not only massive but automatic.
    The Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 12 610x375
    With the bright side covered, it is time to look at the dark reality of the Wattman and how it may fare in the real world. The lithium-ion battery pack has a capacity of 12.8 kWh and the estimated weight, which is not advertised, is probably around 100 kg (30 percent of the bikes weight). This means that the bike can operate only 5 minutes at full power. Although people are not likely to be riding around at full throttle all the time, this time does limit the usability of bike. Voxan, however claims the bike is capable of a very practical range of 112 miles. The figure however is achieved by testing the bike on a mainly urban drive at 21 mph. This means the battery will last about five and a half hours at a power of 2.4 kw (3.2 hp). However, it seems unlikely that the bike will be used this gently, even in the city.
    Voxan Wattman being charged via a European outletThe Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 6 610x455
    The Wattman does, however, make up for this short time cap with a quick charging time. With access to a 220 volt, 150 amp power source, 80 percent charging can be achieved in a mere 30 minutes. This does make up for the limit on range, but is really hard on the battery (meaning short battery life).
    The design of the bike consists of an aluminium exoskeleton which replaces the tubular frame of conventional bikes. The rear suspension is also unconventional, consisting of a four-link suspension which provides a smoother ride.
    A comparison of the Wattman and Lightning Motorcycle?s SuperBike shows that although the SuperBike is short on power (125 kW/165 hp), it does not lack in performance in any way. The SuperBike?s 0-100 mph time is an amazing 3 seconds (compared to Wattman?s 5.9 seconds) and the top speed of 166 mph is also greater. This is due to the 140 kg difference in weight between the two bikes, with Wattman being the heavier of the two. A diet for the exoskeleton based bike seems highly unlikely, meaning that enhanced performance seems a far way off.
    Although there are a few lacking points, the Voxan Wattman still shows us that electric vehicles can be just as exciting and exclusive as any of their fossil fuel consuming counterparts. Pictures of the bike can be seen below.
    The Wattman being introduced at the Paris Motor ShowThe Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 7 610x359Front view The Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 23 610x406The Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 22 610x406The Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 21 610x406Top viewThe Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 20 610x245The Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 19 610x406Rear ViewThe Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 9 610x406The Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 10 610x406Front suspensionThe Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 18 610x329Rear suspensionThe Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 17 610x366Riding controlsThe Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 16 610x398Side viewThe Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 15 610x400The Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 14 610x573The Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 13 610x382The Most Powerful Electric Motorcycle In The World - Voxon Wattman most powerful electric motorcycle 24 610x366
    waqas18's Avatar
    May 2006
    28
    1,501
    23 Post(s)
    3 Thread(s)
    Wow looking cool....
    People with high ego and unnecessary attitude deserves the standing ovation of the tallest finger..
