Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By saboor73
Thread: super power 125 deluxe with cg carb
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Default super power 125 deluxe with cg carb
    I have a super power 125 deluxe a mechanic told me to install cg carb to get performance better but then i noticed that the classic 125 meter says the max rpm is 10k and the deluxe have 11k rpm so if I install a cg classic carb does the carb would give the engine fuel reqiured to have 11k rpm aur I have to find deluxe carb
    moons's Avatar
    Apr 2013
    33
    1,487
    39 Post(s)
    4 Thread(s)
    what do u want to do with 11k rpm?? ride safe bro..
    camry47's Avatar
    Mar 2011
    2,340
    74 Post(s)
    U have to change plug to deluxe dp9xxx as well stater coil, ignition, inner coil, outer coil, min coil all of deluxe then pressure plate clutch plate of original deluxe then u may reach 11k rpm
    Sent from my iPhone using Tapatalk
    camry47's Avatar
    Mar 2011
    2,340
    74 Post(s)
    Most important CDI Unit from deluxe, u have alter the wiring then it will be installed...
