Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By JUNOON007
  • 1 Post By vickytulla
Thread: is it possible to convert a ohc engine to dohc
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Default is it possible to convert a ohc engine to dohc
    today I saw a 70 with a 108 head cylinder and first I thought it would be a 124 head cylinder and when I talk with it onwer he said that the bike is 108 head cylinder and had 4 valves but as I know only dohc engine have 4 valves ohc have max 2 valves is it possible to convert a ohc engine to dohc
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    sohc also can have 4 valve also not big deal.. and no its not possible without major change ...
    Quote Originally Posted by saboor73 View Post
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by vickytulla View Post
    bro if sohc engine could have 4 valves per cylinder so why there is a need to build a dohc engine
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    a SOHC or single overhead camshaft engine uses a single camshaft on the headto lift all the valves, whereas in a DOHC or double overhead camshaft head, two camshafts are used to lift the valves (a camshaft each for intake and exhaust valves) ; normally, SOHCs are used in both16 valve or 8 valve configurations (for a four cylinder engine), but DOHCs are used in 16 valve configurations (or more) only. some exceptions are there.a DOHC layout is better than a SOHC layout in many ways- in DOHCs, the valve timing is more precise, and better valve lift is achieved. also, a DOHC setup eliminates the need for rocker arms, hence creating better timing, and valve contact is more direct too. but of course, these are all in stock form. a SOHC layout, when tuned, can be as efficient as a DOHC,but under proper tuning, DOHCs always achieve more power than SOHCs..
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    there is a website called "letmegoogleitfotyou.com" shoudl I use it
