SUZUKI VSTROM 1000 SPECS AND PRICE IN iNDIA
PRICE EX-SHOWROOM DELHI = 14.5 LAKH RS
Larger 1037 cc engine
Traction Control (two modes, with off), a first on any Suzuki motorcycle
ABS-equipped brakes with new radial-mount Tokico monobloc calipers
Fully adjustable 43mm KYB inverted forks
Better ergonomics
6-way adjustable windscreen
Vertical headlights
Styling inspired by 1988 DR750S
Revised cluster layout
2014 Suzuki V-Strom 1000 specifications and price
Overall Length: 2285 mm
Overall width: 865 mm
Overall height: 1410 mm
Wheelbase: 1555 mm
Ground clearance: 160 mm
Seat height: n/a
Curb mass: 228 kg
Engine type: 4-stroke, liquid-cooled, DOHC 90-degree V-Twin
Bore x stroke: 100.0 mm X 66.0 mm
Engine displacement: 1037 cc
Compression ratio: 11.3:1
Fuel system: Fuel Injection
Starter system: Electric
Lubrication system: Wet Sump
Transmission: 6-Speed Constant Mesh
Primary reduction ratio:1.838 (57/31)
Max Power : 98 hp @ 7400 rpm
Max Torque :101 Nm @ 6400 rpm
Final reduction ratio: 2.411 (41/17)
Front Suspension: KYB 43mm Inverted telescopic, coil spring, oil damped
Rear Suspension: Link type, coil spring, oil damped
Rake/Trail: 25 ̊30? / 109mm
Front Brakes: Twin Disc
Rear Brakes: Single Disc
Front Tire: 110/80R19M/C 59V
Rear Tire: 150/70R17M/C 69V
Ignition System: Electronic
Fuel Tank Capacity: 20 litres
Oil Capacity: 3.5 liters
