Results 1 to 15 of 15
Like Tree21Likes
  • 5 Post By faiz.aslam.121
  • 1 Post By talhabinomar
  • 2 Post By himmi_Pak
  • 3 Post By faiz.aslam.121
  • 3 Post By munnapk89
  • 1 Post By himmi_Pak
  • 1 Post By a-b-c-d
  • 1 Post By uk4455
  • 1 Post By uk4455
  • 1 Post By uk4455
Thread: Proper 'Running' Procedure For New Motorbikes
    bilalayub919's Avatar
    Apr 2008
    Mirpur
    25
    330
    13 Post(s)
    Thumbs up Proper 'Running' Procedure For New Motorbikes
    Asalam O Alikum,
    As am I, many others also are newbies in the biking world. Many want to learn and many have just 'kick and ride' kind of concept.
    As a learner, I want to know what is the proper way to do 'running' of a new motorbike. Things that are essential to know, important dates, changes or mods or any other point that an new biker should know to get the best out of his/her machine and longevity.
    Thank you.
    faiz.aslam.121's Avatar
    Jan 2013
    Oslo
    21
    7,464
    5
    148 Post(s)
    4 Thread(s)
    Copied from various posters. All credits goes to them, R1 and Chery.
    Pay attention to the following during the break in procedure:
    1- For the first 1000 km keep the engine speed below 6500 rpm in all gears and bike speed must be below 60 km/h and avoid riding at the same speed for a long distance.
    2- Frequently inspect the connecting parts for tightness; tighten brakes, clutch, throttle, chain free play, tyre pressure and engine nut bolts as necessary.
    3- Check whether the bike transmission system and brake system is overheating, if has find out the reason and solve the problem.
    4- Replace the engine oil and clean air filter element every 500 km during break in.
    5- Warm engine up before operating, and limit speed during first 1 ~ 5 kms.
    6- Change the speed as load increased to avoid the engine wear or damage, do not overload the engine.
    7- Avoid hard breaking.
    The main objective should be to stay below or equal to 5.5k RPM. Not saying that this is the best possible way to break in the engine but only telling my experience.
    ==> First 200 kms @ max speed of 40km/h, 5.5K RPM
    ==> 200-500 kms @ max speed of 60km/h, 6.5K RPM(oil change)
    ==> 500-800 kms @ max speed of 90km/h, 7.5K RPM
    ==> 800-1000 kms @ max possible speed that I could get on an open road keeping in mind the safety. (oil change @ 1000kms, tuning, nuts tightened etc)
    All the stages in the run in period, the speed must be kept variating. Do not drive for more than 30-40 minutes without giving a rest to the bike for the first 300 kms.
    Turbo lag is like foreplay. You know it's coming. And it's gonna be good.
    talhabinomar's Avatar
    May 2011
    26
    2,472
    38 Post(s)
    Be careful till first 1000 kms. After that you can run it according to your will.
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    Warm your engine on idle for 2-3 mins, then dont exceed 50 km/h for 300 km and 60 km/h for uptill 1000 km. change oil at 300km and then 1000km , dont drag the bike or push to beyond half gear ratio. avoid steep slopes and continous travel. Pilllon riding* dual riding is not recommended. ignore sounds engine or other parts make it will be gone after tunning...... Other than ,all advices wear the helmet as must.
    Apr 2008
    Mirpur
    25
    330
    13 Post(s)
    I have heard bikers saying 'Shuru Say He Bike Pay Zor Daalo Taaky Engine Khulay". Any reality in that?
    Sent from my A900 using PW Forums mobile app
    Jan 2013
    Oslo
    21
    7,464
    5
    148 Post(s)
    4 Thread(s)
    Quote Originally Posted by bilalayub919 View Post
    You're meant to drive at different speeds so engine parts face different type of loads. Drive at 20 for a bit then 40 etc.
  7. 08-03-2014, 04:07 AM
    Site Banned
  8. #7
    suzukialtomehran's Avatar
    May 2005
    Sargodha
    26
    7,289
    16 Post(s)
    its not a rocket science just ride it slow and gentle till 500 km and change its oil, then change oil at 1000km along with full inspection like tightening nuts and bolts some tuneups, than afterwards just change oil with intervals of 1200km or 1500km and you are good to go.
    Two of the best quotes of Punjabi : 1. Rull tan gae aan! Per Chass aa Gae ai!, 2. Gal Pya Dhol Ty Wajana Penda ay.
  9. #8
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    engine pe zor daleen gaay tu wo beth jayega if not properly run during intial 1000km
    loagon ki kiya bat krtay ho bhai applied for likha hua hota hy zero meter pe 3 banday aur sauda dal kr shaan se le kr ja rahay hotey
    hain uc waqat tu chal jaata hy per kuch ersay baad pata chalta hyjab engine ki awazien change honi lagti hain aur ucki bas ho jati hy
  10. #9
    Jan 2013
    Oslo
    21
    7,464
    5
    148 Post(s)
    4 Thread(s)
    I abused my Cg 125 Euro II. When I first got it. Drove like an uncle for the first 300km, after that, started to check top speed, practising wheelies and other stuff. Ended up breaking 3 odo meter cables within 2 months. Done enough Patakhas(backfires) and sold it to a friend for 85,000 after 2 months. It was unregistered so yeah who cared. At least I fun
  11. #10
    munnapk89's Avatar
    Feb 2012
    Rawalpindi
    122
    6 Post(s)
    Proper Running Procedure For New Motorbikes -1372715Proper Running Procedure For New Motorbikes -1372717
    For those who dare, the future is in skies ...
  12. #11
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Quote Originally Posted by himmi_Pak View Post
    what should be the ideal weight to put on new bike?
    so u means to say mr x and mr y bought the same bike at same time from same shop.
    now mr x is 60kg and mr y is 98kg so by the time they reach the house mr y bike will be in bad condition by all aspect as more load is on his bike. and after a month or so he will be selling his bike but mr x bike will be in top nouch condition.
    what should be the ideal weight for a rider to ride a bike?.what do bike manufacture says on their manual?
    really looking for some good answer from anyone.
    as i never rode alone after buying the bike all which i have kept in past 24 years.
    Help others so that u can be Helped
  13. 09-03-2014, 11:11 AM
    Senior PakWheeler
    Reason
    Not needed
  14. #12
    Site Banned Follow
    a-b-c-d's Avatar
    Dec 2013
    45
    i think sufficent suggestion is already given. what else? do contribute rather spoiling the thread
    mr x and mr y doesnt matter what difference they have
    but MR X+ MR Y + MR Z weight on one bike that is what he wanna say to avoid that. i think OP gets it but you are a little slow in learning
    Quote Originally Posted by archon2001 View Post
  15. #13
    Site Banned Follow
    uk4455's Avatar
    Sep 2013
    Bristol
    126
    3 Post(s)
    what are you finding following question's anwer in manual?
    GOOD ANSWER IS ALREADY MENTION ABOVE BROUGHT BY FAIZ ASLAM of @chery and @R1
    what you want to write a book on break in period ? please contribute
  16. 09-03-2014, 11:27 AM
    Senior PakWheeler
    Reason
    Not needed
  17. 09-03-2014, 11:29 AM
    Site Banned
    Reason
    Not needed.
  18. 09-03-2014, 11:33 AM
    Senior PakWheeler
    Reason
    Not needed.
  19. 09-03-2014, 11:34 AM
    Site Banned
    Reason
    Not needed.
  20. 09-03-2014, 11:36 AM
    Site Banned
    Reason
    Not needed.
  21. 09-03-2014, 11:36 AM
    Senior PakWheeler
    Reason
    Not needed.
  22. 09-03-2014, 11:38 AM
    Senior PakWheeler
    Reason
    Not needed.
  23. #14
    Site Banned Follow
    uk4455's Avatar
    Sep 2013
    Bristol
    126
    3 Post(s)
    no i dont escape. i like to report your nonsense so it get deleted. going off topic and personal with a member is dicourgaing on the professional forum
    engine is new and it requires more effort in that case. in pakistan people abuse the bike and get happy
    the manual you are refering to ever you read it on the full? its clearly mention in it to avoid the pillon riding
    oh really thats the best u can do to escape
    whats personal attack pls explain.
    but my question remains the same. why avoid pillion riding on new bike?
  24. 09-03-2014, 11:46 AM
    Site Banned
    Reason
    Not needed.
  25. 09-03-2014, 11:48 AM
    Senior PakWheeler
    Reason
    Not needed.
  26. #15
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Quote Originally Posted by uk4455 View Post
    which manual i got gt0110, gs150,cd185twin, triumph tiger cub, all with manuals none of them say avoid pillion riding.
    kindly refer the manual u are taking abt.
