Results 1 to 5 of 5
Like Tree4Likes
  • 3 Post By hidalgo
  • 1 Post By user-xxx
Thread: Carburator
    sualehsmarty's Avatar
    Jun 2013
    52
    2 Post(s)
    Unhappy Carburator
    maine apna carburator khol kar saaf kiya tha lekin jab maine usko saaf karne k baad wapis laga diya aur us k baad se hi bike start nahin ho rahi ab main kiya karun please help bike 2 din se aese hi khari hai
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    check the float levels, they should be in same height. check if any jet is not tighted .check if fuel is coming aswell
    good luck
    and next time do not open and clean your carb
    legend will revive soon
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    bahu us ky carburator main fuel nahi a raha .
    it is a little problem with a little solution.
    float stuck ho gya hy or incorrect set hy.
    ap ko carburator ka float adjust karna paray ga.
    1- remove your fuel pipe.
    2- remove and open carburator.
    3- i think the float bowl will be empty or having a little fuel.
    4- adjust your "float level " with google help.
    5- bahi kahi ulta float to nahi laga dia ???
    ------------------------------------ALTERATION/MODIFICATION SEPARATE HUMAN FROM BEAST-----------------------------------------
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Are you sure that you put everything back in as it should be?
    even if the float level is not correct, the bike should starty start
    https://www.facebook.com/OsamaAbbasPhotography
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3990 Post(s)
    94 Thread(s)
    6
    check the float needle valve - clean with a dousing of carb cleaner and make sure it can move.
