Results 1 to 10 of 10
Like Tree5Likes
  • 1 Post By Shafin619
  • 1 Post By jadoon1992_vxlimited
  • 2 Post By Zigi
  • 1 Post By jakoozd
Thread: GS150 Gear " Khattak" Sound and some other problems. Need Advice
    dmszack's Avatar
    Jan 2013
    631
    17 Post(s)
    Default GS150 Gear " Khattak" Sound and some other problems. Need Advice
    Dear All,
    1.Does any one know how to get rid from the gear changing Khattak sound in 1st and 2nd gear, i asked the showroom guy and he said that just buy rear drum rubber from Rafiq Autos(They have made their own) which works better then original, please advice.
    2.Recently a weared type of sound is coming from engine Head side " tik, tik , tik" either it is tappet sound or something else . I am also scared regarding timing chain.
    3. Yesterday the front brake lever light was not working, i just checked the Front brake assembly where the switch is installed and suddenly a spark taken place and the fuse was burned hence i have to change the Fuse. Does any one know how to resolve this issue.
    Thanks
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    I also hate the annoying khattak sound recently change the rear drum rubber but it made no difference. I think we have to put more big rubbers to vanish the khatak sound.
    Sent from my Desire HD using Tapatalk 2
    4 wheels move the body 2 wheels move the soul
    dmszack's Avatar
    Jan 2013
    631
    17 Post(s)
    Quote Originally Posted by Shafin619 View Post
    Have you tried the Rafiq Autos personnel drum rubber ?
    jadoon1992_vxlimited's Avatar
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    Quote Originally Posted by dmszack View Post
    those rubbers are just okay i have tried them alot of times. not that good. but you should try it once. if it solves your problem, then you can continue using it. regarding the tik tik sound, go to a good suzuki showroom, if it is the sound of the timing chain, it can be adjusted without an issue. nothing to worry about that.
    people need to grow up sometimes and act MATURE !
    dmszack's Avatar
    Jan 2013
    631
    17 Post(s)
    Quote Originally Posted by jadoon1992_vxlimited View Post
    Which show room you guys prefer to go ? I just go to Suzuki IG Motors at Punjab Chowrangi.
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    altough ig motors is quite near to my place and i recently got my bike tuned from there. but i prefer to go to suzuki fr motors akbar road. regarding the timing chain, it is better to take to bike to fr motors and they will solve the problem.
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    here see this link hope fully yr 1 problem will be solved.
    https://www.pakwheels.com/forums/mem...suzuki-gs150-2
    brake switch wire is short from assembly u need to replace it with new 1.
    for 3rd problem u need to see the workshop.
    Help others so that u can be Helped
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    Nope bro
    Zigi's Avatar
    Nov 2012
    29
    31
    2 Post(s)
    Dear All,
    Man, i've had a GS since 2008 and it did produce this sound when i was using 20w-50 but has vanished when i started using 5w-50... the fault doesnt lie with the rear drum padding as the the khattak (sorry ppl from Kohat ) sound originates from the gear box and has a jerk to it too.
    The tik tik tik sound is normal as you might have bought a new byk and this sound is normal during the running as the head, piston and the rest assembly is getting used to the thrashing... I blv this tik tik tik sound happens more when you push the throttle to its limits and then switch off the byk n lets it cool??? if yes then it's natural and nothing to worry if not get it checked
    Well stuff lyk this happens, when you live in this country and buy products made of as careless a workman as is evident... so dnt stress it
    Peace
    Don't sell your self that much that people stop buying you
    Site Banned Follow
    jakoozd's Avatar
    Dec 2013
    104
    2 Post(s)
    Pak Suzuki ki koi bhi cheez utha lo worst quality. Sell it buy a CG.
