Results 1 to 6 of 6
Thread: engine block alteration
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Default engine block alteration
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    bump.........
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    @Xulfiqar bhai lil help needed
    Synchrony's Avatar
    Oct 2011
    97
    5 Post(s)
    Most engine blocks will accommodate a single gear upgrade without alterations rather easily. Would help to know what application the upgrade is needed for.
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    bigger gears mean ? size wise ? or different gear ratio ? if possible what gears ratio is available in market ? me too interested
    Quote Originally Posted by Synchrony View Post
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by asjdsm View Post
    for example cd 70 has 4 speed transmition suppose I want to put 5 speed transmition in it every gear has 0.25mm gap in between the length of 5 speed transmition will be atleast 0.3mm longer so if we put 5speed in it we will have to make more room for bigger transmition
