not yet!
Slam bro, I am living in Lahore. What about Tyres? I want to install fat tyres in my cg 125 i have no idea what to do. Please give some useful suggestion.
How Fat are we talking
Dear friends I'm in Mexico and here the 125cg still sells for the 2016. Can I use that one for a cafe protect? ?? Thanks
Yes you can If you spend money on new and you have to spend more to build this thing it will cost you double, I suggest you to buy a old model, even if you found only chasis, you can start your project
Even in pakistan, CG125 is still coming from company
did you complete your project?
NiCE NiCEE!!!
what about the EXHAUST...??? dosri TARF ki TASWEER PLZ!
[/quote]
can i got your number? looking for guideline
Can you list the process and parts plz? and from where you got them. thnx
http://www.throttleshrottle.org/rides--riders/honda-cg125-cafe-racer-by-ali-asad
Please check the link n you will know
Hey, im looking for a good mechanic in lahore for my '81 CB400T cafe racer. I need some general maintenance on the engine and wiring. I also need some of the parts repainted.
Thank you for the help
Salam BrothersNeed ur help. I own a Honda cg 125. I'm also planning to build a cafe racer. Do bigger tires as above affect the acceleration & handling of the bike? Is it possible to put a Suzuki gs 150 engine for more power? Also, tell me an approx cost (without engine swap).RegardsTony D Morgan
For bigger tires you will need a wider swing arm and fork. For the engine suzuki gs 150 engine will not fit directly, you will have to modify the chasis alot, try using lifan 250cc engine it will easily fit on the existing settings. About the cost it depends, costed me around $150.
Thanks a lot brother. God bless you
hi sir i ve honda 125 2015 and need to modify as cafe racer.can u plz suggest us for best person for full work.
awsum work bro can u plz help me for this same.my number is 03125797230
The best person to do this is your self or find individuals with special fabrication skills and make them do this under your supervision
Hello I'm going for a cafe racer build and i wanted to know that can a honda deluxe support 4.00-18 tyre in the front? Or is the space not wide enough for that size the stock size on it is 2.75-18
I have honda cd 125 2019 model and want to convert into a cafe racer sort of a bike. I have no knowledge about this conversion. Wanted to know about the budget I must keep in mind and the major changes. Any one who's kind enough to tell ?
