Results 1 to 6 of 6
Thread: "Chun Chun" sound from the bike making me crazy !
    xavier9's Avatar
    Sep 2012
    74
    Default "Chun Chun" sound from the bike making me crazy !
    Hi PW members...
    i own an Honda CD 70 2012 model...the problem is there is some "chun chun" sound coming from the rear shock from the last few days...i took the bike to a service station, there they sprayed some diesel into the shocks and that irritating sound was gone....but after 2 days, it again started making the same sound...i really want to get rid of this damn sound...is there anything wrong with the shocks? or do i need to get the shocks sprayed from somewhere else?
    Thanks
    bilalayub919's Avatar
    Apr 2008
    Mirpur
    25
    330
    13 Post(s)
    Rubber sook gye hogi may be. Oiling karwa lain set ho jye gi.
    sent from Mars via International Space Station.
    arslan.asghar1's Avatar
    Jun 2013
    Rawalpindi
    28
    96
    Try sparaying wd-40 on the shocks ..
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Shocks k pumps ki problem bhi ho sakti hay
    kuck mahinay pahlay yah problem bike main a gaya tha
    jb main pillion rider k sath bike chalata to chun chun sound ata tha
    main nay tawaja nahin di aur phir shock ka pump leak ho gaya tha ap pump check karwa lo
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Bro did you checked the chain? As chun chun sound also comes from chain if sprocket set is used beyond its life
    xavier9's Avatar
    Sep 2012
    74
    Thanks guys...took the bike to a mechanic, he opened the nut to which silencer is attached (below the right 'tappa'),took out the bolt a bit from other side, lubricated it with oil and then i never got that annoying sound again.
