Page 1 of 4 123 ... LastLast
Results 1 to 20 of 74
Like Tree75Likes
Thread: Deluxe Top speed >_<
    noman222's Avatar
    Sep 2013
    64
    Angry Deluxe Top speed >_<
    I have Deluxe 2014 and here is the poor top speed :@ i dont know why they installed the speedometer of 160 kmph at least it should touch 120. may b i have problem with my bike.. kindly share your experiences.
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    you should be glad its touching 110km/h and deluxe's 110 is actual 110 as its meter is accurate
    mine deluxe used to go only 90-95km/h with me only once touched 110km/h that too when it was
    brand new only few hundred km's driven don't know since than what happened it used to max: go 90-95km/h mostly 90
    Even 250cc CBR'S engine need to work hard to touch speed of 160km/h
    160km/h is impossible to achieve on this 125cc its just stupid meter
    given in this bike to impress people & same thing applies in pridor 100 too
    it has meter of 140km/h meter, dial of 120km/h is more than enough for all pakistani bikes
    bilalayub919's Avatar
    Apr 2008
    Mirpur
    25
    330
    13 Post(s)
    Mine 2012 deluxe did 105 max aur bht jaan lagaa kay
    sent from Mars via International Space Station.
    noman222's Avatar
    Sep 2013
    64
    hmm u r right i checked a lot of videos of top speeds cbr 150 nd 250. both are international brands 150 touching round about 140 and 250 is 160+. AHL making us fool only giving the 160 dial
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    @poster you are getting more than maximum of your deluxe bike(if it is in its genuine factory settings) look at the RPM you are getting 100% of it though there are many many Dlx bikes which do not produce such high RPM(at stock factory settings) normaly it reaches to 9 or 9.5 hardly and at speedo u wil be getting 95 to 97 hardly so with factory settings your bike is 100% OK - Further if you wanna increase your Dlx speed you have to make 3 changes in the bike first is Bigger CDI unit (which was used until 2005 CG Models) second change you have to made is Sprocket set of the bike - dlx has 43 teeth sprocket u have to alter it with CG sprocket which has 39 teeth - 3rd and the last change is of Muffler, use Chrome Muffler and pull out all the plates of muffler then check out your rocket dlx it wil easily achieve 115 to 120
    Main tay Honda ee lay saa'n !!!
    noman222's Avatar
    Sep 2013
    64
    dear its totally genuine condition and totally factory setting. 8101 km driven.. u can check. and i m 1st owner..
    Quote Originally Posted by khanthegr8 View Post
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    than it is Ok my friend no problem with the bike just enjoy it
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    Why is the top speed of deluxe so low? Even a 70cc with 125 carb and custom sprocket can touch 100km/h -_-
    4 wheels move the body 2 wheels move the soul
    umarkhan1's Avatar
    Nov 2010
    Sargodha
    2,308
    6
    8
    51 Post(s)
    4 Thread(s)
    too dangerous..
    btw how do you managed to take the pic of speed at 110kmph
    Just Do It Your Self!!!!!
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    @shafin company ko customer ki safety bhi chahiye - dlx is an animal if it is unleashed then how to stop it at such enormous speed
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    Hmm khan bhai you are right if the speed limiter is removed from both Deluxe and GS then god know how will we able to stop these machines
  12. #12
    tucknoloji's Avatar
    Jan 2010
    35
    572
    22 Post(s)
    2 Thread(s)
    Hitting maximum speed is just like giving multiple heart attacks to the bike engine... its better to stay safe rather trying hitting maximum speed without taking care of safety measure...
    Sent from my Galaxy Nexus using Tapatalk
  13. #13
    noman222's Avatar
    Sep 2013
    64
    by using left hand
    Quote Originally Posted by umarkhan1 View Post
    too dangerous..
  14. #14
    wakman2003's Avatar
    May 2006
    42
    912
    yes i can see your left hand with mobile in the shadow
    drive safe!
  15. #15
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Brother if you keep reving your deluxe's engine in red line then i am adraid you will fry your engine very soon
  16. #16
    Apr 2008
    Mirpur
    25
    330
    13 Post(s)
    Speed is ecstasy, you need more and more!
  17. #17
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    Quote Originally Posted by bilalayub919 View Post
    Damn true
  18. #18
    leo_ali's Avatar
    Oct 2013
    143
    3 Post(s)
    Default Deluxe Top speed >_<
    I think 100km/h is too much for two wheeler especially these bikes n also dangerous
    Sent from my iPhone using PW Forums mobile app
  19. #19
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Quote Originally Posted by leo_ali View Post
    Yup you never know when an ama g or rairi wala appear from nowhere in the middle of the road.... and then
  20. #20
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    khan bhai kia ap explain kar saktay hain
    k deluxe k top speed company nay kasy
    restict ki hay kyun k is k andar electronuc control to
    hay nahin phir speed kis tarah restrict ho sakti hay
