Page 2 of 7 FirstFirst 1234 ... LastLast
Results 21 to 40 of 140
Like Tree156Likes
Thread: Review - Qingqi Trail DP 150cc
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Cool Review - Qingqi Trail DP 150cc
    Dear Friends..
    Sharing my experience of Qingqi Trail 150cc...
    Review  Qingqi Trail DP 150cc -1422405
    Bike: Qingqi DP 150cc
    Model : 2014
    Category: Dual Purpose Trail
    Engine: 150cc Single Cylinder 4 Stoke Air Cooled
    Tank: 10 Lit
    Battery: 12V 7 AH
    Seat Capacity: 2 Person
    Starting System: Self & Kick
    Max Speed = 120km
    Break Front/Back = Drum
    Best Average Till Now = 38km/Lit
    First Run of 380km from LAHORE TO ISLAMABAD
    1st Run
    Got Average of 29km/Lit, Very Much Comfortable in long ride no pain in shoulders & back, Pick is not good which is a big? Mark for DP Trail Category ? GS 150 Engine is far better in pick & Torque then this Engine.
    1st Tuning
    Tuning & other thing which need to recheck (carburetor Cleaning & Setting, Taped Adjustment, Oil Pump Checking, Gear Ring Checking, Front Shock Oil Change & Setting, Break Leather Checking & Complete body Inspection & Tight up all the nuts & bolts.
    2nd Long Run of 850 km Kashmir
    Got 38km/lit, Break Performance Increased, Smooth Shocks & better pick then before No Trouble on long run even continue ride of 8hr. Yes Missing on Peak heights which can be reduce in low gears but still annoying it will break your motion & speed. No problem in MUD, WATER (Event Half Engine in water) & ROCKS. Good Grip & breaking as well, shocks are very much comfortable on rocks.
    3rd Long Run of 350 km Banjosa/Toli peer
    Got 34km/lit, Front Brake need service nut got slip, Smooth Shocks, & Missing @ height Toi Peer ... Remove the air filter to chk but same performance so need expert advice... Rest non stop all the way...
    1600 km on the Clock ...till now.
    Engine Demonstration & Maintenance (Post # 47-52)
    Parts Replacement / Availability
    After buying any brand which is unknown to market parts are as important as bike itself. Here is the list of the parts which I easily find in case of emergency Happy to see that all parts are easily available.
    Rear Brake Shoe = CG 125
    Clutch Cable = CG 125
    Front Brake Cable = CG 125
    Chain = CG 125
    Electric Coil = CD 70
    CDI Unit = Cg 125 (Grips need to Replaced if u need to put Orginal one of honda but if u need to put the same then u can get it Chinese brand)
    Carburetor = Honda Deluxe 125.
    Front back Lights Bulb = Honda 125
    4rth Long Tour
    (Before Another long tour )
    Rear Brake Shoe Changed = CG 125 Best Quality Used
    (Post # 83)
    Clutch Cable Changed = CG 125
    TOP BOX
    (Post # 84-85)
    Bought Water/Heat proof Bag
    Capacity 16lit
    Good thing it comes with Plastic Containers which is inside of the box which sustain its shape & provide safety for inside things.
    Overall Review: Satisfied with the performance & Handling, Light weight front make it much comfortable on sharp turns, and good in grip.
  2. #21
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Sharda AJK
    Review  Qingqi Trail DP 150cc -1422459
  3. #22
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    On the Way to TAOBAT
    Review  Qingqi Trail DP 150cc -1422460
  4. #23
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Review  Qingqi Trail DP 150cc -1422462
  5. #24
    a_k
    a_k is offline
    a_k's Avatar
    Feb 2005
    39
    2,015
    4 Post(s)
    looks like a copy of KE-175
    Review - Qingqi Trail DP 150cc - images?qtbnANd9GcTUuPfkjZhdFPrHZN9zPihSNfODtwevTueA119fP6f 6bmbsFLJJA
    If better were within, better would come out.
  6. #25
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by a_k View Post
    Ke have a very good name & rapoo in its time.. So good to know they copy the frame...
  7. #26
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Review  Qingqi Trail DP 150cc -1422471
  8. #27
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Beautiful View on the way to taobat.
    Review  Qingqi Trail DP 150cc -1422472
  9. #28
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    2st Time Fall from Trail 150 bike while passing from the SNOW ... Mud all over me & on the bike.. Nothing happen only got a TICKET for Front no Plate..
    Review  Qingqi Trail DP 150cc -1422638
  10. #29
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Finally Reached Taobut....
    Review  Qingqi Trail DP 150cc -1422474
  11. #30
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Trail 150cc to Swaik Lake
    ISB-RAWAT-MANDRA-CHAKWAL-C
    HO SAIDAN SHAH- Thllian Dam- SWAIK LAKE- ISLAMABAD
    Review  Qingqi Trail DP 150cc -1422475Review  Qingqi Trail DP 150cc -1422476
  12. #31
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Thllian DamReview  Qingqi Trail DP 150cc -1422477
  13. #32
    dohc525's Avatar
    Feb 2011
    220
    11 Post(s)
    Mani bhai respect your words buddy do contact me on my number 03472005252 if any one needs studds Genuine DOT helmet
  14. #33
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Trail 150cc to Toli Peer & Banjosa
    Islamabad - Rawalakot - Banjosa - Toli Peer - Islamabad
    Review  Qingqi Trail DP 150cc -1422481Review  Qingqi Trail DP 150cc -1422482
  15. #34
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by dohc525 View Post
    U r more then Welcome ...
  16. #35
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    @ Toli Peer
    Review  Qingqi Trail DP 150cc -1422483Review  Qingqi Trail DP 150cc -1422484Review  Qingqi Trail DP 150cc -1422485
  17. #36
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    @ Banjosa
    Review  Qingqi Trail DP 150cc -1422488
  18. #37
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Not a bad bike overall, but anyone buying make sure you tighten all the nuts and bolts yourself before you hit the road.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
  19. #38
    jadoon1992_vxlimited's Avatar
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    good to see a chinese bike performing so well. hoping to see it in the market soon. how is the result of the drum brakes? do they perform well? it was displayed in expo long ago but still not available in the market. how much you got it for?
    people need to grow up sometimes and act MATURE !
  20. #39
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by jadoon1992_vxlimited View Post
    Yes inshLALLAH it will be available in market soon... Rest Drum break is good till now... Front need disk as mostly in trail tough track are on the way so for better grip it must have disk.. Rest completed 2100km & still in original pads.. No CHEEE CHAAAA sounds in water & service req ... But for mentally satisfaction will check on tuning & share some pics..Soon....
  21. #40
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by 7thgear View Post
    Yes that is must ..
