Page 5 of 7 FirstFirst ... 34567 LastLast
Results 81 to 100 of 140
Like Tree156Likes
Thread: Review - Qingqi Trail DP 150cc
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Cool Review - Qingqi Trail DP 150cc
    Dear Friends..
    Sharing my experience of Qingqi Trail 150cc...
    Review  Qingqi Trail DP 150cc -1422405
    Bike: Qingqi DP 150cc
    Model : 2014
    Category: Dual Purpose Trail
    Engine: 150cc Single Cylinder 4 Stoke Air Cooled
    Tank: 10 Lit
    Battery: 12V 7 AH
    Seat Capacity: 2 Person
    Starting System: Self & Kick
    Max Speed = 120km
    Break Front/Back = Drum
    Best Average Till Now = 38km/Lit
    First Run of 380km from LAHORE TO ISLAMABAD
    1st Run
    Got Average of 29km/Lit, Very Much Comfortable in long ride no pain in shoulders & back, Pick is not good which is a big? Mark for DP Trail Category ? GS 150 Engine is far better in pick & Torque then this Engine.
    1st Tuning
    Tuning & other thing which need to recheck (carburetor Cleaning & Setting, Taped Adjustment, Oil Pump Checking, Gear Ring Checking, Front Shock Oil Change & Setting, Break Leather Checking & Complete body Inspection & Tight up all the nuts & bolts.
    2nd Long Run of 850 km Kashmir
    Got 38km/lit, Break Performance Increased, Smooth Shocks & better pick then before No Trouble on long run even continue ride of 8hr. Yes Missing on Peak heights which can be reduce in low gears but still annoying it will break your motion & speed. No problem in MUD, WATER (Event Half Engine in water) & ROCKS. Good Grip & breaking as well, shocks are very much comfortable on rocks.
    3rd Long Run of 350 km Banjosa/Toli peer
    Got 34km/lit, Front Brake need service nut got slip, Smooth Shocks, & Missing @ height Toi Peer ... Remove the air filter to chk but same performance so need expert advice... Rest non stop all the way...
    1600 km on the Clock ...till now.
    Engine Demonstration & Maintenance (Post # 47-52)
    Parts Replacement / Availability
    After buying any brand which is unknown to market parts are as important as bike itself. Here is the list of the parts which I easily find in case of emergency Happy to see that all parts are easily available.
    Rear Brake Shoe = CG 125
    Clutch Cable = CG 125
    Front Brake Cable = CG 125
    Chain = CG 125
    Electric Coil = CD 70
    CDI Unit = Cg 125 (Grips need to Replaced if u need to put Orginal one of honda but if u need to put the same then u can get it Chinese brand)
    Carburetor = Honda Deluxe 125.
    Front back Lights Bulb = Honda 125
    4rth Long Tour
    (Before Another long tour )
    Rear Brake Shoe Changed = CG 125 Best Quality Used
    (Post # 83)
    Clutch Cable Changed = CG 125
    TOP BOX
    (Post # 84-85)
    Bought Water/Heat proof Bag
    Capacity 16lit
    Good thing it comes with Plastic Containers which is inside of the box which sustain its shape & provide safety for inside things.
    Overall Review: Satisfied with the performance & Handling, Light weight front make it much comfortable on sharp turns, and good in grip.
  2. #81
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    Cool! thanks pal.
    Quote Originally Posted by mAYH3M View Post
    IS 4151 is an Indian standard for Protective Helmets for Motorcycle Riders.In its latest revision it is line with the European Commission's,EC Regulation 22,Revision 5
  3. #82
    Zeeshan206's Avatar
    May 2009
    38
    1,779
    27 Post(s)
    10 Thread(s)
    Wonderful Bike
    <<<***ALHAMDULILLAH***>>>Yah ALLAH tera Shukar
  4. #83
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Review  Qingqi Trail DP 150cc -1428961Review  Qingqi Trail DP 150cc -1428962Review  Qingqi Trail DP 150cc -1428963Review  Qingqi Trail DP 150cc -1428964Review  Qingqi Trail DP 150cc -1428965Review  Qingqi Trail DP 150cc -1428966Review  Qingqi Trail DP 150cc -1428967Review  Qingqi Trail DP 150cc -1428968
    Review  Qingqi Trail DP 150cc -1428984Review  Qingqi Trail DP 150cc -1428985
  5. #84
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Review  Qingqi Trail DP 150cc -1428970Review  Qingqi Trail DP 150cc -1428972Review  Qingqi Trail DP 150cc -1428973Review  Qingqi Trail DP 150cc -1428974Review  Qingqi Trail DP 150cc -1428975
  6. #85
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Review  Qingqi Trail DP 150cc -1428977Review  Qingqi Trail DP 150cc -1428978Review  Qingqi Trail DP 150cc -1428979Review  Qingqi Trail DP 150cc -1428981Review  Qingqi Trail DP 150cc -1428982Review  Qingqi Trail DP 150cc -1428983
  7. #86
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    a big big plus for upcomming tour ... but bura mat manana dost offcourse its highly usefull per pta nahi looks men bas so so he hai ....
    Quote Originally Posted by d3vil View Post
  8. #87
    talhatoor's Avatar
    May 2014
    44
    Qingqi trails :O ... i hope they would not get abused by converting into a rickshaw .... as in pakistan, Qingqi / "Chingchi" literally means a rickshaw ...
    HI NI JAWANIYAY ... KITHAY DHAKAY PAYE KHANI AYN
  9. #88
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by vickytulla View Post
    Well Bro I am of the same view on 1st look.. but u know after putting side bages it look awesome dont worry InshALLAH will upload more pic in upcoming tour u will see it really suit her...
    Let em share some thing Hope you like this
  10. #89
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by talhatoor View Post
    Chaly ga Sub chaly ga... It rocks Other shokes.....
  11. #90
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Yeh Chaly ga .... @vickytulla
    Review  Qingqi Trail DP 150cc -1429013
    Review  Qingqi Trail DP 150cc -1429014Review  Qingqi Trail DP 150cc -1429015
  12. #91
    talhatoor's Avatar
    May 2014
    44
    I own a faithful GS150 ... laikin is ko dekh kr dosri shaadi ka mood ban raha hy...
  13. #92
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    this bag is beautiful and looking way better ..
  14. #93
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    lolzzzzzzzzzzzzzzz Kar lo kar lo...
  15. #94
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Different projects are ongoing will try all resources to make it TRUE ADVENTURE BIKE Stay Tune For More Updates
  16. #95
    noblerider's Avatar
    Apr 2014
    666
    14 Post(s)
    2 Thread(s)
    bro whats the max top speed u have got till now???
  17. #96
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by noblerider View Post
    After 2nd Tune up max that i can make easily is 115...
  18. #97
    noblerider's Avatar
    Apr 2014
    666
    14 Post(s)
    2 Thread(s)
    thats great and whats the feeling on 100 plus speeds?i mean vibration or smoothness and road grip?
  19. #98
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Well Mostly its solid in body so no vibration of body..
  20. #99
    talhatoor's Avatar
    May 2014
    44
    buddy zara price range to bata do ... ta k zara plan bnaya ja skay ....
  21. #100
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    125-130k..
