Results 1 to 5 of 5
Thread: need help for my junoon
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Default need help for my junoon
    I had bought a Yamaha junoon 2006 model since the bike is 8years old I am facing some miner issue for which I need help
    1.The clutch plates are worn out and I have herad that even dyl has stop production of junoon so I would need clutch plates are clutch plates available in market
    2.When I start the bike in there some tik tik sound which vanishes after 10-20sec
    3.the rear break drum of the bike has a crack because of it the braking of bike is pretty weak
    4.the tappet cover leaks oils
    can some one help me solve this problems
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Quote Originally Posted by saboor73 View Post
    Seems like an abused one...
    Shakeel autos on MacLeod road is ur answer... go there for parts.
    And new sharief autos is the authorized dyl mechanic... also on MacLeod road. You should get ur work done from there... but beware that guy is a s c u m bag... he'd open ur bike, and then start doing other bikes which come for tuning etc. so dont let him waste ur time...
    he'd open up ur bike in the day and wont finish it till late evening...
    tik tik sound is a loose piston...
    goon goon sound is of clutch baksa during idle
    clutch plates are easy to find, rear brake drum should also be available... tappet nut needs cleaning and silicone
    Sent from my HUAWEI G700-U10 using Tapatalk
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by Automotorsport_Lover View Post
    thanks for your reply but I live in Karachi not lahore
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    @Automotorsport_Loverdoes the loose piston will effect the performance of the bike and if I want to fix this issue does it need to open the head and chamber
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    First get its tuning done from a proper and professional place, authorized experienced dealer.
    A similar tik tik sound is made if tappets are loose, so prior to suspecting the piston. Get its tappets done from a real expert.. never show this bike to local ustads, mistris or honda mechanics..
    Its settings are all different.
