Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 169
Like Tree54Likes
Thread: Black Animal ( Deluxe )
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    Default Black Animal ( Deluxe )
    After selling CG Dream in 97K I've bought DELUXE once again, this time I've modified it with sprockets, Bigger CDI Unit of CG 125, replaced it's carburetor with CG 125 Classic's carburetor but bike started missing at higher RPM's ( I thought CG is faster than Deluxe so there might be some role of Carburetor in it but I was wrong Deluxe Carburetor has 15 Jet Carb while CG Euro 2 & CG Dream has 14 Jet Carb so I put back Deluxe Carb on it and now bike is Okay ) it is performing awesome and reaching top speed of 118km/h. Before modification it hardly achieve 95km/h. I didn't did any kind of running/break-in operation to the bike, just bought it and punished it at the spot and it is doing well. Let me gather all the modifications at one place
    1. Front & Rear Sprockets changed with CG Euro2 sprockets ( gear ratio of bike increased with this, 5th gear is now effective to bike and gives engine power of 1 complete gear, before changing sprockets 5th gear only provide rest to the engine, Bike's Vibration is reduced to a surprising limit )
    2. Bigger CDI unit installed in it ( bike is receiving full current now, RPM is reaching at it's top 11 in all gears now )
    3. Chrome Muffler installed ( Bike is throwing it's exhaust with full pressure outside )
    4. Iridium plug installed ( Bike is not breaking current at top speeds even )
    5. Removed foam from it's Air Filter ( Bike is getting extra air blow in the filter )
    Similar Threads:
    Main tay Honda ee lay saa'n !!!
  2. #101
    awais_400's Avatar
    Jul 2009
    37
    63
    Khan bhai its all done.? .? or some thing more? ? thats you thinking about to increase the speed.if its top speed is 118 km/h so why ahl show 160 km/h speedin speedo meter.
  3. #102
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    I've complained many times to the management about this issue, that if Deluxe don't goes across 100km/h we should reduce it's speedometer range, it should be 120 or 140 but nothing responsive from management
  4. #103
    awais_400's Avatar
    Jul 2009
    37
    63
    Quote Originally Posted by khanthegr8 View Post
    Khan bhai its all done.? .? or some thing more? ? that's you thinking about to increase the speed of Black animal...
  5. #104
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    @khanthegr8 my friend has an 2012 euro 2 cg 125 and he has complaint of lesser acceleration than the older models so he talked to many mechanic one told him to change hi push rod with custom made aluminium one bcoz the euro2 has very thin and low quality push rod is it true
  6. #105
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    Quote Originally Posted by saboor73 View Post
    I don't know inside story of Engine's so It will be better to consult a mechanic, I don't know about these things
    Quote Originally Posted by awais_400 View Post
    From my side I did the best I can do to increase Deluxe top speed, & after completing all the test I've sold out this bike in 115K
  7. #106
    Alir1's Avatar
    Aug 2013
    233
    2 Post(s)
    khan sab what are you driving now ?
    Sent from my GT-I9300 using PW Forums mobile app
  8. #107
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    At the moment I've two bikes Red Deluxe & a Black CG Euro2
  9. #108
    bhatti007's Avatar
    Dec 2013
    21
    257
    6 Post(s)
    khan sahab wo blue deluxe kaha geya sirf pic main hi dekha hai,na showroom main nazar aya na road pe?
    speed + vibration= cg125
  10. #109
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    @Bhatti wo Sindh Police ke liye banaya gaya tha on demand, 200 bikes
  11. #110
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    DHA Lhr has placed an order of 100 units of Pridor bikes in Yellow color
  12. #111
    Farhansa's Avatar
    Oct 2006
    8,715
    5
    84 Post(s)
    I have seen yellow Pridors on road.
  13. #112
    bhatti007's Avatar
    Dec 2013
    21
    257
    6 Post(s)
    Quote Originally Posted by Farhansa View Post
    Wo DHL corrior walon ki h
    Sent from my A10 using PW Forums mobile app
  14. #113
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    koi bhi color ya koi bhi special accessories on demand lagwai ja sakti hain kisi bhi model pe.minimum order should be of 50 bikes
  15. #114
    Farhansa's Avatar
    Oct 2006
    8,715
    5
    84 Post(s)
    Khan bhai agar bike k cylincer ka color utar jaye thora sa or rust ana shuru ho jaye to kya waranty may replace ho jata ha?
    Sent from my LT29i using PW Forums mobile app
  16. #115
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    Cylinder is not under warranty, you have to bear it
  17. #116
    camry47's Avatar
    Mar 2011
    2,340
    74 Post(s)
    khan bhai you're right, but acceleration down hogi lekin top speed ziada achieve hogi lekin is sey koi farq parta hai ?
    sb se ziada achievement 15 36 per arahi hai lekin ratio 2.6 hoga acceleration kum hojaegi lekin 20% difference in top speed, kia deluxe ka engine itni power generate ker sakta hai is top speed ko achieve kerney ke liye agar ap wala cdi unit use kerain ziada open exhaust ya chrome wala
    Black Animal  Deluxe  -1454076
  18. #117
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    congrats for the new bike
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
  19. #118
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    @camry47 definitely bro it has the ability of generating such high power, platinum spark plugs used for racing purpose also do the effect. Deluxe doesn't have sharp pick up even at stock condition so very few change in pick up will occur
  20. #119
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    congrats on buying an animal
    you are right its real animal
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
  21. #120
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    Default Black Animal & Red Power Machine
