Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By ammarzahid
Thread: Oil found in my new Raiders Air filter.
    tabish90's Avatar
    Dec 2013
    39
    Default Oil found in my new Raiders Air filter.
    Dear all, I purchased a suzuki raider a week ago and after completing 400kms I went for 1st tuning. When the mechanic took out the Air filter it had engine oil deposited on it. Is it normal? Is the breathing system of sprinter/raider deposit oil on the surface of air filter?
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Quote Originally Posted by tabish90 View Post
    yeah its normal, my sprinter had the same (red) oil on the air filter. actually its necessary for air filter to have oil otherwise its not going to trap dust particles. dont worry
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Yup oiling a foam air filter is mendatory
    Abroad, there are specific oils for foam air filters(mostly in trail bikes) but here these are not available hence gear oil is the way to go
    tabish90's Avatar
    Dec 2013
    39
    Quote Originally Posted by ammarzahid View Post
    Thanks for the response I thought that perhaps the bike had crankcase breathing problem
    1 more thing, I've observed that the front susension of Raider gives a lot of jerks on smooth roads due to simple irregularities of the road surface, is that normal too?
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    yea unfortunately you'll have to deal with it.. stop the bike and make shock absorbers go in. if they're going with minimal effort then your raider is performing normal. no problems
    mtmoghul's Avatar
    Apr 2009
    609
    7 Post(s)
    3 Thread(s)
    Yes, Its normal.
    ....It is supposed to be automatic, but actually you have to push this button ....
Tags for this Thread
