Results 1 to 11 of 11
Like Tree4Likes
  • 1 Post By fazalwahab11375
  • 1 Post By abdul.moeez91
  • 1 Post By xeevil
  • 1 Post By xavier9
Thread: How to make the Headlight beam of CG 125 better?
    xavier9's Avatar
    Sep 2012
    74
    Default How to make the Headlight beam of CG 125 better?
    My cg's beam is very weak, having a stock bulb. Is there any 'bulb' better than the stock one that can be fit inside, without changing battery or the whole headlight casing?
    abdul.moeez91's Avatar
    May 2014
    25
    28
    bro use HID
    Fawad1617's Avatar
    Dec 2012
    Gujranwala
    314
    5 Post(s)
    Quote Originally Posted by abdul.moeez91 View Post
    bro use HID
    HID use karny sy new battry ki zarorat?
    Sent from my IM-A760S using PW Forums mobile app
    fazalwahab11375's Avatar
    Jan 2012
    Select City
    29,466
    36
    842 Post(s)
    23 Thread(s)
    "Ache Eye Devices".. ???
    Please enlighten https://www.pakwheels.com/forums/new...please-dont-do
    bro use HID
    Pakwheels on the MAP; http://bit.ly/ZVyXcZ
    May 2014
    25
    28
    Clean the head light internal body by a duster and after that there use a slightly tissue paper to make a shining surface , and after that you,ll get a fine result .
    xavier9's Avatar
    Sep 2012
    74
    bro use HID
    No HID bro....
    xavier9's Avatar
    Sep 2012
    74
    Unable to open the front part of headlight.....as i detach the front part from the black holder backside (HANDI), i have no idea how to detach glass from the silver part...perhaps you could help me...it has a bolt which opens from very front, but opening it doesnt help...any idea???
    xeevil's Avatar
    Mar 2006
    30
    36
    I think u can attach a relay to increase the light... Take it to a good electrician... He'll do the charm for you..
    xavier9's Avatar
    Sep 2012
    74
    Quote Originally Posted by xeevil View Post
    yep....gonna try that...thanks
  10. 20-07-2014, 09:11 PM
    r1
    Senior PakWheeler
  11. #10
    angel82's Avatar
    Nov 2005
    34
    996
    6
    284 Post(s)
    6 Thread(s)
    Quote Originally Posted by xavier9 View Post
    Before adding relay you need to upgrade its reflector(Handi) to a better one. because after adding relay and a 55watt bulb your current reflector may fry after some time. It doesn't cost you much.
    There are couple of threads in which they used Osram night breaker 55watt bulb that produced enormous result. Search for it you'll get a good guidance from it.
  12. #11
    xavier9's Avatar
    Sep 2012
    74
    i asked about Osram bulb and Narva S2 bulb but couldnt find either from Isb.....
    I was having issues with my battery...it was dead. So i put a new battery and the headlight beam got better....not to something i wanted but i can live with that....
