Hi guys assalam o alaikum i have honda cg 125 my bike engine is over heating what should i do for it ? Give me the suggestion plz
How do u know that ur bike is overheating. What r the symptoms?
Sent from my LT29i using PW Forums mobile app
Do this more often and you may need a new engine
which oil are you using? and do you regularly push the engine to such limits?
there are many reason of over heating lean fuel/air oil pump not working perfectly wrong oil selection
problem solved or not???????
Hi there.I just recently bought a new 2006 125 and it is overheating and some times the noise comes out from the head cylinder what will be issue with it.
How can i know if my bike has a problem with the clutch plates???
its usually pressure plates which cause heat in bike but sometimes i ur cam gear is old it also creates heat so i would suggest to get rid of sounds and heat do complete head cylinder side workdone otherwise you would be replacing parts foreer issue would not b resolved hope it helps you
list is here to do proper repair
