Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Xulfiqar
Thread: Lubrication solution for bike parts
    raza1850's Avatar
    Apr 2014
    6
    Default Lubrication solution for bike parts
    I came across some threads regarding general maintenance of the motorbike, specifically lubricating parts such as cables and chain.
    The Links:
    https://www.pakwheels.com/forums/bik...ke-maintenance
    https://www.pakwheels.com/forums/bik...1626-chain-wax
    https://www.pakwheels.com/forums/bik...hain-lubricant
    Some of the lubrication products are in the 2000-3000 range which is quite expensive for a few hundred ML's of Lube. I have attached pictures of an interesting grease i found today. Second picture jo can ki backside ki picture hai usme 'RECOMMENDED USES' ki heading ke under likha hai, '' Motor pivot points- Bearings- Winches- Latches- Pistons- Conveyors- Overhead Door Tracks- Cables- Bearings- Runners- Water Pumps- Gear and Break Mechanisms- Metal Parts- Hinges- Catches'' in case sahi se nazar na araha ho to. And yes it says Bearings twice in the list on the can its not a typo.
    Khair 400ml ka can hai Which i got for Rps. 600.
    What do you guys think?
    Similar Threads:
    • #2
      Xulfiqar's Avatar
      Aug 2003
      Other
      38
      24,402
      131
      3989 Post(s)
      94 Thread(s)
      6
      this is grease in spray form, its not chain wax. This can makes it a bit easier to apply grease in very small areas where you cannot use a brush or a grease gun.
    • #3
      margallar's Avatar
      Oct 2009
      9,960
      6
      283 Post(s)
      4 Thread(s)
      i think this should be good for things like lock cylinders and door hinges. 600 rupees is great, the 3m aerosol costs more than 2000
      haters gonna hate, potatoes gonna potate
    • #4
      Xulfiqar's Avatar
      Aug 2003
      Other
      38
      24,402
      131
      3989 Post(s)
      94 Thread(s)
      6
      never apply grease to lock cylinders unless there is a way to refresh that grease, I have been told by old and succesful locksmiths that beeswax is better, you dont want anything that can attract dust or dirt. beeswax does not.
    • #5
      sleepyhead's Avatar
      Jun 2014
      Faisalabad
      147
      2 Post(s)
      WD-40 has a trillion use cases but it is not supposed to be used as long term lubrication on vehicle parts.
      I bought German grease:
      Liqui Moly 50 Litho HT as shown in the thread https://www.pakwheels.com/forums/bik...62#post4453923.
      It is 400 grams, bit expensive but will last for the life time of any local bike
    • #6
      raza1850's Avatar
      Apr 2014
      6
      sleepyhead- lol that looks like some good stuff and a good investment the local bikes deserve a little love however didnt see any of the LM here, this is the next best thing, plus i found it a bit cheaper than you mentioned.
      Xulfiqar- Sir its still a grease, but is it any better?
      margallar- i think it can do better than door hinges, a door hinge doesnt need grease that can take 145C. Why would anyone spend Rps.2000 on grease for a door hinge, thats what the little blue WD-40 is for.
