Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 94
Like Tree59Likes
Thread: swapping 2stroke frame with a 4s motor
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Default swapping 2stroke frame with a 4s motor
    i have a stupid query i want to swap a 4s engine in a 2s frame , frame is kawasaki sports , engine is cg look a like , how to make engine mounts?? I m confused , seniors please help me in this regard
    legend will revive soon
  2. #41
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    will see that later on
  3. #42
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    you are spending too much time trying to hammer the engine into the frame, the problem with your approach is that the frame you are using is full cradle with a very peculiar engine mount.
    anyway - you can still put it there, for that you will need to make some heavy mods. firstly you need to measure the centre axle height compared to the front legs of the frame and the top too. Once done you need to fabricate a new mount bracket for the bottom and remove the original kawasaki frame bracket that is welded to the spine. You can make new brackets for the front and top mounts easily once you get the back of the engine installed.
  4. #43
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Glad you are here sir Xulfiqar. The thing is that cg frame is different engine kinda setels into it which can t happen in this frame . Kindly simplify about the mounts m still confused
  5. #44
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    the CG125 frame is one where engine is stressed member, meaning its part of the frame bracing, the kawi frame you have is not, its a cradle frame.
    if you can shoehorn the engine to sit between in the cradle then you need to make a heavy steel mount bracket for the rear bolts, to accomplish this you need to keep the rear swing arm pivot exactly where it is - ergo measure it correctly - not just futta and feeta but correctly make a jig that can hold a centering piece over the axle hole. that way you can place it back on exact spec after you have welded in the new bracket for your engine.
    If your cradle does not allow it then you need to modify the frame to be like the international market Honda H100S/H125S frame. you already know the H100 frame is same as CG but with missing front leg, the international models had the leg.
    c'mon you are a custom builder - its easy as cake.
  6. #45
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    The last line has boosted me up . And h1oo idea is amazing
  7. #46
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    Tabahi machaye howi hai frame k saht Good Going!
    engine ghus tu gya hai frame me but its to high it has to be lowered at least ~2' to align with the Chimta (Engine sprocket - choti garari) must be in line with your rear chimta or else chain will grind and eat your Chimta.. or may get snaped...
    also engine Oil pan must be parrallel to the ground when frame is standing on its tyres or else the Oil pump will starve and will not be able to feed the head with oil hence an engine seize...
    jo uper wala pipe kat diya hai usko alteration k bad dubara thora uper ker k he sahi mager ligana zuror its one of the mandotry part of this design.
  8. #47
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    m onna fit it like engine is fitted in poagios frame ( refring to bolting points
  9. #48
    angel82's Avatar
    Nov 2005
    34
    1,004
    6
    284 Post(s)
    6 Thread(s)
    @hidalgo today i got time to view the thread and i must say you are pretty serious about it. Ya aar ya paar wala mamla lag raha hai
    Best of luck brother
    Quote Originally Posted by vickytulla View Post
    These were first 2 things that came in my mind as well. Front sprocket should be in alignment of rear sprocket or the chain won't move freely. 2nd thing is engine balance. it should be horizontally straight so oil can flow properly.
    3rd thing about the head bolts it should be properly centered and i recommend that you weld those hooks at the end I mean after fitting the engine at the bottom. It will decide its location itself.
    Quote Originally Posted by hidalgo View Post
    Yes going fine Piaggio frame is the simpler frame.
  10. #49
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    here is the deal , i m going to remove all mount tabs from frame , front nd rear and m gonna try to settel the motor in like its shown in pic after that i ll fabricate the mounts
    few isses m facing
    this frame is not as wide ( engine belly is not settling in )
    have to clear space for carb .
    progress is slow because m doing it at my own and helping my self as well all friends are busy these days
    also need advice at the engine mounts i m going to make , which material how much mm etc.
  11. #50
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    @angel82 its always aar ya paar
  12. #51
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    hacked off the front legs . to make engine sit low it was necessary mr blade helped me in t his regard , the best tool i had so far , i pour some water at metal nd blade nd it cuts quickly and easily . now i m hope full that i have got sorted out the mounts issue .
  13. #52
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    here is the tricky or you may say fun part , when i try to place rear upper mount of engine in to frame's upper mount , the heads bolt strikes to the piece of pipe i had earlier removed . i need to remove it and whats bothering me is that any work regarding to head will cost me to remove the engine from frame. front mounts are going to be easy peasy . one mount will be re fabricated
  14. #53
    enigmatool's Avatar
    Sep 2009
    39
    236
    atleast 7 to 8 amp 12v battery is enough, easily available in the market.
    gs-150 genuine battery
  15. #54
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    here is the deal , i had choped off the frame few dfays back , then got busy and could not mount the engine , today i tried to moutnt the engine using the stock engine mounts but engine rfused to go in , i removed tappet cover n tappet plate then Mr engine went in , i talked to Tariq butt sab a day back and he was saying about making ut double cradel , sir i fear i will face alignment issues , let the pics do the talking , open to discussions
  16. #55
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    a simple idea i have and i think its going to pay well , if any one has seen a naked frame of ga150 or piaggio , the sub frame is very low as compared to main frame , if i give main frame a height of couple of inches , this issue can be solved , open to discussion ,
  17. #56
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    having alignment issue as well of sprocket and swing arm , sprocket seems more out wards as compared to chimta
  18. #57
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    a fellow pakwheller did such a prohect on honda mb100 , have a look at his built frame , i m getting pisse off dil to ker raha ha aik khulla dulla frame hi bna lu jaan goot haey
  19. #58
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    frame like this can end all of the clearance ********
  20. #59
    vickytulla's Avatar
    Oct 2009
    8,424
    38
    876 Post(s)
    31 Thread(s)
    so what are the updates hid, from thead what I learn that ur are still in the design fase so far... from Pics I understand you need to move the engine further forward to use some spance from above also to maintain the COG on a reasonable position.
  21. #60
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Vicky bhai actually i m doing this at my own so using stock mount is a sort of majburi at the moment , secondly sir the thing is as i have said about r.p and gs frame who have a taller main frame are much roomy as compared to the simple n straight 2s chasis , so now an improved and re enforced pr re fabricated main frame is needed, which should be tall nd roomy as gs nd rp frames , or the easiest solution is to screw this frame n get a new cg frame and bolt on engine fit . Tension khatam , but this inqilab is testing my patience to limits m running out of time
Tags for this Thread
