Results 1 to 10 of 10
Thread: Bought a CG-125 2003 model! Planned to upgrade to 200! :)
    deevad321's Avatar
    Mar 2013
    20
    6
    Cool Bought a CG-125 2003 model! Planned to upgrade to 200! :)
    Assalamu Alaikum Guys!
    As the title says i have bought a dead cg 125 recently. I am planning to upgrade it to 200 which includes changing of crank, piston, head and a few more things i cant remember. will soon post the pictures
    iNCEPTiON's Avatar
    Aug 2011
    Rawalpindi
    528
    18 Post(s)
    Best of luck
    Sent from my beloved iPhone 5 using Tapatalk
    deevad321's Avatar
    Mar 2013
    20
    6
    Sure! Project on completion!
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by deevad321 View Post
    If you haven't started the project I would say drop the idea instead of boring engine buy a xl180 engine It will be much more powerful,more economical and more cheap as it is bolt to bolt swap on cg
    deevad321's Avatar
    Mar 2013
    20
    6
    Quote Originally Posted by saboor73 View Post
    Dear the engine boring has been completed its getting fitted by the so called USTAd . Can i know how much an xl180 engine would cost!
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    20-25k max
    2468's Avatar
    Apr 2008
    36
    3,508
    7 Post(s)
    3 Thread(s)
    If that 180 engine kick back fire while starting then it will free your ankle for sure, and braking would also remain an issue as disk does not match the front shock angle set up, front wheel lift up during first gear shoot would also remain an issue due to shorter wheel base, so you end up with a totally confused and impractical bike.
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by 2468 View Post
    sir I am not a very strong guy but I can kick start a xl-180 a friend mine own one I don't think it so hard to kick yes have to apply much more force than cg but a xl-180 back fired when kick it for first gear shoot if you can't handle it use cg carb and as most of ppl call it cb 180 so as cb series bike has 18" most of ppl ad rear 18" in it
    2468's Avatar
    Apr 2008
    36
    3,508
    7 Post(s)
    3 Thread(s)
    It can be kick started but I mentioned its back fire consequences
    Carb is not an issue, the issue is the chassis capability to handle the power
    and about brakes, even disk is not suitable for its chassis
    but even then if one likes it with all these flaws then its up to ones choice, but safety is high in my priority list
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    How you cg 200 share some pic of engine if possible
