Results 1 to 16 of 16
Like Tree3Likes
  • 1 Post By amjad635
  • 2 Post By jadoon1992_vxlimited
Thread: Engine Oil for GS150 EuroII
    mohsinnaseem's Avatar
    Apr 2006
    32
    10
    Default Engine Oil for GS150 EuroII
    Salamz everybody!
    this is my very first thread.
    I am quite confused with the engine oil selection for my Suzuki GS150 EuroII 2013/14
    I previously had GS150 2008 and I was stuck with ZIC Hiflo 20W-50 as the previous owner was using the same oil and engine was set to 20W-50.
    I recently upgraded to GS150 2013/14 (5000KMS) and like every-other person I am also dis-satisfied with Suzuki Genuine Oil 10W-40
    Just because its a new bike so I cannot use 20w-50 so I start using ZIC A 10W-40 Synthetic. but it seems that Zic A doesn't last too long because after every 500KMS the engine sound was getting loud and I was changing the oil for every 500KMS
    so now, as 20W-50 is not recommended for new engines and 10W-40 was not performing well after 500KMS
    the OIL shopkeeper suggested me to go for ZIC M 15W-40 as its is in the middle of 10W-40 and 20W-50. It seems quite sensible to me and I decided to go for ZIC M 15W-40 Gasoline.
    Now the sad story is my just after 2KMS the Tappet start sounding too loud, and even the gear starts heavy sound (KHATTAK) on every shift. NOW I am again going to oil shop to drain this ZIC M 15W-40.
    BUT which oil should I select now. I am very much confused. as I tried all the three grades of ZIC and I am not satisfied.
    20W-50 can be a good selection but I cannot use it in new engine and secondly it requires much more time to pump and its thick as well.
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    you are using improper engine oils in your bike that is why you facing issues with gears smoothness
    and engine performance Zic Hiflo & Zic A & Zic M are car engine oils you should buy proper motorcycle
    engine oil for your bike i suggest you to buy Zic 4t 20w40 mineral engine oil for you GS150
    our one senior fellow Gull bhai is using this oil in his GS150 and it is performing best in his bike i used this oil
    in my pridor 100 & now using in my CD70
    Engine Oil for GS150 EuroII -1476772
    https://www.pakwheels.com/forums/bik...le-engine-oils
    Apr 2006
    32
    10
    Thank you amjad for you recommendation, I will definitely look for ZIC 4T 20w40. but throughout pakwheels forum i saw everybody suggesting LiquiMoly Racing 4T. (Still confused)
    iNCEPTiON's Avatar
    Aug 2011
    Rawalpindi
    528
    18 Post(s)
    Even I will suggest u liquimoly as I have tried every oil in my CG 125 and this oil is best ! gears are smooth . Sound is awesome even after running more than 600Kms so give it a try and give ur feedback here
    Sent from my beloved iPhone 5 using Tapatalk
    Apr 2006
    32
    10
    Bro, which grade Liquimoly you suggest? 10w-40 or 20w-50? my bike is Jan 2014- 5500KMS done
    iNCEPTiON's Avatar
    Aug 2011
    Rawalpindi
    528
    18 Post(s)
    Quote Originally Posted by mohsinnaseem View Post
    Go for 10W-40 first and then try the other one !!
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Liqui moly is very good quality engine oil but its imported engine oil so expensive
    and not easily available its available in big cities as khi isl & lhr
    you can give a try to LM but from local brands Zic 20w40 is excellent engine oil
    always try to purchase big or known dealer in city this way you can be safe from buying fake engine oil
    Apr 2006
    32
    10
    Finally i switched to Zic 4T as recommended by amjad. Liquimoly was not available though the shopkeeper was saying to go for Mobil 1 but he also said that you will feel no difference.
    So I decided to go for ZIC 4T semi-synthetic 20w-40 but it was available in 0.75 ltr so I had to buy two. The tappet sound magically went away. I'll update rest of the results soon.
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    use zic 20-40w but 950ml
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    My dear i also insert zic 4T semi synthetic oil grey color box first time in my GS150 in my thinking it was a thick oil but found it a amazing thing now gears & also engine is going so smooth & all sounds are gone from engine.now engine is very very smooth in real first time i am enjoying its drive
    Apr 2006
    32
    10
    Thanks Hami khan... Its been three days and I am also observing better performance and lesser engine sound... Thanks you all guys for your suggestions.
  12. #12
    m1r
    m1r is offline
    m1r's Avatar
    Jan 2006
    28
    1,676
    Where to get liqui moly original here in karachi ?
    Sent from my Nexus 4 using PW Forums mobile app
    "The sum of intelligence on the planet is a constant; the population is growing."
  13. #13
    jadoon1992_vxlimited's Avatar
    Dec 2008
    24
    3,388
    7
    69 Post(s)
    6 Thread(s)
    Quote Originally Posted by saboor73 View Post
    950 ml? why?
    people need to grow up sometimes and act MATURE !
  14. #14
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by jadoon1992_vxlimited View Post
    950 ml? why?
    If you want to use thick oil don't pour full quatity of oil a lil less thick oil will do its job but due to a lil less quantity the pressure on engine will be lesser
  15. #15
    Dec 2008
    24
    3,388
    7
    69 Post(s)
    6 Thread(s)
    ye science tou pehli baar suni hai april 2011 se 20w50 havoline he use kr rha hun kbhe 1 litre dalne se pressure tou nhe aya engine pr. bara bara likha hai k 1 litre dalna hai on the user manual and on the engine. kon se ustaad ne btaya tha ye?
  16. #16
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    It not recommended and it just for user satisfaction becoz he is getting afraid of thicker oil
