Results 1 to 10 of 10
Like Tree3Likes
  • 2 Post By imranbhatti
  • 1 Post By saboor73
Thread: Coolant for motorcycles
    TM
    TM is offline
    TM's Avatar
    Apr 2004
    43
    2,715
    29 Post(s)
    Default Coolant for motorcycles
    Dear all, can anyone recommend a good quality coolant for motorcycles? If I am not wrong coolant for motorcars are a bit different than the motorbikes...am I right?
    "Never drive faster than your Guardian Angel can fly."
    angel82's Avatar
    Nov 2005
    34
    997
    6
    284 Post(s)
    6 Thread(s)
    Quote Originally Posted by TM View Post
    I dont think so. If its water cooled both works on same mechanism.
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Coolant type differs for different applications the aluminum, iron or other metals engine blocks requires different type of coolant it also depends on type of radiator water pump used for specific applications. So its better to search first that wat type of coolant ur bike requires & then search for specific product. D u have some reference/recommendation available fro manufacturer?
    Exploring Machines is my Passion...
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Which bike you have
    TM
    TM is offline
    TM's Avatar
    Apr 2004
    43
    2,715
    29 Post(s)
    The bike has a aluminum radiator, so guess I cannot use the ordinary coolant that we use in our motorcars...forget it...i have decided to use the bottled water (one of the three leading brands in the country)
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    I believe Pyro coolant is compatible to aluminum radiators.
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    And use it with a mixture of water..
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Well recently I have observed some issue with aluminium radiator application which is being used with Pyro Coolant & that issue has been observed by some other users as well so better not to use Pyro coolant for aluminium radiators till further confirmation
    @7thgear
    Are u referring to Pyro ? that's pre diluted & doesnt need addition of Water
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Quote Originally Posted by imranbhatti View Post
    @7thgear
    I once read somewhere that antifreeze has chemicals in it that don't get fully activated until you add water. Most antifreeze is sold as a concentrated solution. So not sure if that goes true for all radiator types or not.
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by 7thgear View Post
    yes it need water to activate but not simple water it need distilled water simple water will just dilute it
