Results 1 to 12 of 12
Thread: Cg 125 gear jerk...?
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,303
    49 Post(s)
    Default Cg 125 gear jerk...?
    Bike is cg 125.
    Problem is when i release the throttle, there is a jerk, as if there is too backlash. A clunking sound is also heard when the jerk is considerably stronger. Chain tension is ok, rear damper bushes are replaced a while ago.
    Seems to me that there is too much play in the gears... please comment!
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by metalhead View Post
    Bike is cg 125.
    what kind of jerk kindly elaborate
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    is your cg 125 euro 2 or non-euro
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    deluxe or classic?
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,303
    49 Post(s)
    Quote Originally Posted by saboor73 View Post
    deluxe or classic?
    Its classic 06' model.
    The jerk is there when the engine start engine braking that is when the throttle is returned. Feels like there is backlash in gears and it engages in the other direction with force and may be it slips the clutch a little so making a "dug" sound.
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    which oil are you using? how many kilometer the bike has clocked?what overhauld history of your engine?how long you have facing this problem
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,303
    49 Post(s)
    Oil: Havoline, and level does not fall till next oil change.
    Driven: too much, (no record/history)
    Changed: Chain-Sprocket set, clutch. Previous history unknown.
    I have bought it few months back. Changed the chain-sprocket set with the damper bushes on the first day and later changed the clutch. At the time of clutch change the mechanic said that the slight gear "ghar ghar" noise at higher speeds is due to some gear that is not genuine. I asked if we replace it, he said the new part will have the same noise so let it be like this. sometime after clutch change i started to notice the play in gears. May be it was there before but did not noticed.
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Tight the screws little bit which are highlighted in below picture:
    Cg 125 gear jerk? -1484982
    Dream is not that which you see while sleeping it is something that does not let you sleep.
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Masla klutch ka hi hay
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Masla clutch ka nahin yay center axle ka hay check center axle nut is tight
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    @metalhead! kindly check and inspect the sprockets, transferring power to the rear wheel. I am pretty sure its worn out sprockets causing this problem.
    Riders on the storm ... literally.
  12. #12
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,303
    49 Post(s)
    Quote Originally Posted by r1 View Post
    You mean to adjust the clutch
    ... but i think it is ok. Mechanic has also checked it.
    Quote Originally Posted by JUNOON007 View Post
    Clutch is new, please explain what kind of problem...
    Quote Originally Posted by hamikhan View Post
    By Center axle nut, you mean rear axle bolt and nut? or something else, please elaborate...!
    Quote Originally Posted by abobobilly View Post
    Chain sprocket set is new. I will check it and the bushes too. But the mechanic said its the clutch drum gear and its pinion or something like that or he said it could be the clutch drum wear...
