Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Like Tree13Likes
Thread: Oil Leakage in Engine Area What to do?
    ArshadXaidi's Avatar
    Sep 2012
    26
    494
    3 Post(s)
    Unhappy Oil Leakage in Engine Area What to do?
    Dear Pakwheelers,
    I Have Jialing Jh70 which is performing very well and good average but i saw today oil seepage/ leakage on specific point of engine area is there any danger sign because i am worried that isnt these are the sign of engine life is over (i mean complete overhauling) or does these 3 bolts have seals that have to be changed
    kindly tell me what to do with this issue i want to get rid of oil leakage
    Regards
    Proud Owner of Jialing Jh70 Model 2003
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Bhai g engine purana ho jay to aisa karta hay koi masla nahin is ko saf karo aur dakho k dobara kb tak seepagd ati hay
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    Oil Leakage in Engine Area What to do? -1493768
    @ArshadXaidi
    No major issue just the seal shown in red is leaking .. need to get it replaced .. if the oil is not being reduced signaficantly (as it looks in the pic) then no urgency as well
    "You have not lived today until you have done something for someone who can never repay you."
    Sep 2012
    26
    494
    3 Post(s)
    thanks for quick reply whats the role of big nut in this picture can i change it or does it have seal in it?
    Sep 2012
    26
    494
    3 Post(s)
    if i want to change seal of gear seal as shown in red circle does it changed without opening engine how this seal can be changed?
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    the bigger one looks like the drain nut .. it is also possible that the leather seal of drain nut has given away ...
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    Quote Originally Posted by ArshadXaidi View Post
    go to mechanic and show him leakage area .. on a second thought it look like oil spill from drain nut and air pressure has taken it upwards .. not a costly expenditure .. u'll get it replaced in no time
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    if the oil is not being reduced much then get it changed on next oil change since you'll have to drain oil for the operation and i'm quite certain that it is a drain nut issue .. initially i thought it is a car gear box then i read your post again to know that its a bike ..
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    just to be sure clean it and see if u get the same pattern back after 3-4 days .. otherwise it is just the footprints of oil outside the nut during oil change
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    the bigger one is for oil drain and the seal is of shifter lever going into transmission case.. clean the under belly use warm water with liquid soap and brush, wipe clean with rug and leave over night to check actual seepage
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    KamranAslam's Avatar
    Apr 2006
    Select City
    14,245
    7
    295 Post(s)
    11 Thread(s)
    9
    as @Naweed: Mentioned its the gear lever seal
    others all good, no need to worry.
    Replace the seal hardly 45 or 50 rupees.
    My CD70 same seal changed this thursday.
    I am only responsible for what I say, not for what you understand..
  12. #12
    mohsinwahhab's Avatar
    Jul 2013
    26
    1,133
    19 Post(s)
    don,t mind bro but its time to sell this and buy a good bike
  13. #13
    jadoon1992_vxlimited's Avatar
    Dec 2008
    24
    3,388
    7
    69 Post(s)
    6 Thread(s)
    Quote Originally Posted by mohsinwahhab View Post
    100-200 k kaam k liye bike sale krni parti hai? and how do you know that it is not a good bike? kiun k aik seal leak hai?
    people need to grow up sometimes and act MATURE !
  14. #14
    Jul 2013
    26
    1,133
    19 Post(s)
    Quote Originally Posted by jadoon1992_vxlimited View Post
    bhaiya jii thandey ho jao men ney koyi usey gali nhe dai di hai jo aap ko aag lag gye hai > mere kehney ka matlab yeh tha key bike ka engine apni life pori kar chuka hai 11 saal chal gya hai is lye sell kar do aur koyi dosri bike lo baki us ki khud ki marzi jo chahye chalaye
  15. #15
    ammarzahid's Avatar
    Jan 2013
    Rawalpindi
    1,766
    178 Post(s)
    6 Thread(s)
    Unhon nay leak ka solution poocha hai. I think hes wise enough to know when to sell his bike
    Sent from my LG-F160K using PW Forums mobile app
  16. #16
    Sep 2012
    26
    494
    3 Post(s)
    sir its jialing bike and i love it much more love than gd cg rp gs i hope u understand
  17. #17
    Jul 2013
    26
    1,133
    19 Post(s)
    Quote Originally Posted by ammarzahid View Post
    Ji bhai inhoon ney solution pocha tha aur men ney inhen suggestion di hai order nhe dya
    Sent from my ZTE BLADE III using Tapatalk 2
  18. #18
    Jul 2013
    26
    1,133
    19 Post(s)
    Bro I like jialing bike more than any chonda but I don't like its engine it is under powered according to bike weight ager mere pass yeh bike hoti to men is key engine ko 125 cc men upgrade karta
  19. #19
    Sep 2012
    26
    494
    3 Post(s)
    sir but i ask in previous thread professional said that upgrade it to maximum 78cm3 i ask them whether i upgrade it to 86cm3 or 97cm3 my friends suggests to change its engine complete rather than go to upgrade its engine i know its under power but its enough for me
  20. #20
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    the three bolts highlighted by you in pic out of them bigger one is timing chain bolt
    or mechanic say timing chain adjuster can't say anything confirm there is spring inside
    that bolt when remove bolt spring comes out well what ever it is regarding your issue
    and concern may the culprit in only that bolt oil is leaking from it & making dirty other
    engine bolts too i recommend don't get engine opened may be seal are absolutely fine
    its only the leakage from bolt go to the mechanic whom you trust most & is honest
    many mechanics would try to convince you for opening engine by saying chamber seals are broke
    whole engine needs to be open
