Results 1 to 7 of 7
Thread: Help - Leaking Spark plug cap - RP 125
    naveedkhan93's Avatar
    Jul 2014
    Rawalpindi
    44
    Exclamation Help - Leaking Spark plug cap - RP 125
    AOA
    Brothers I just want to know if someone experienced this strange problem with their bike, specially RP-125, as my bike spark plug cap is leaking the spark to body. I have change couple of caps, but the result was same. I can visibly see the spark jumping from plug cap to body.
    Bike is fairly new 2013, under 8K driven.
    Help needed in this regards.
    JustFarooq's Avatar
    Apr 2006
    Faisalabad
    33
    1,037
    29 Post(s)
    May be its an issue of your plug instead of cap
    ALLAH U MMA SALLE ALAA MUHAMMADIN WA BAARIQ WASALLAM
    Jul 2014
    Rawalpindi
    44
    Quote Originally Posted by JustFarooq View Post
    Plug was also replaced many times .... same result
    JustFarooq's Avatar
    Apr 2006
    Faisalabad
    33
    1,037
    29 Post(s)
    Then consult with a good electrition
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by naveedkhan93 View Post
    take a dester start your bike inpect the wire of sprak plug from the cap till end and tape the area from where the current is leaking
    Jul 2014
    Rawalpindi
    44
    Quote Originally Posted by saboor73 View Post
    As I said ... spark cap is leaking spark ... already done the taping; still no use.
    Need Advise from some RP experts ....
    Jul 2014
    Rawalpindi
    44
    -----Any Expert ???--------
