This light is not coming ON in my bike.But when i kick start the bike it does come ON but flickers as with acceleration.Any idea what is the problem.
battery issue
I checked the battery with a Voltmeter it is showing full current 12.70V.So now i have to change the battery.
check battery cables .. does horn/indicators works when just the ignition switch is set to on (bike is not started) ?
Nope no horn/no signal.........
Check fuse.........
Normally when issue is with the battery the lights are dim, however in your case nothing connected to battery is turning on so issue with fuse is more likely.
where is this fuse located.As i opened the meter and checked current at the switch live wire current is present over their.May be the switch gone bad.
open the TAAPA and u'll find a fuse there with the positive terminal of the battery
Ok now the problem is solved the fuse was short circuited.
But today i got in a small road accident on my bike and now my handle is not straight anyone know how to straighten my handle because it feels awkward to drive with a irregular handle.
