Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By saboor73
  • 2 Post By JUNOON007
Thread: Motorbike kick issue
    aliatif777's Avatar
    Jul 2010
    22
    165
    Default Motorbike kick issue
    Today while starting the bike with kick starter, the kick became free it, it does start bike but it doesn't come up automatically like it should. Can anyone tell me what is damaged? The bike is a Honda CD-185.
    Similar Threads:
    Mercedes W126 1980, Triumph Spitfire 1963, MG A 1958, Mercedes 190SL convertible (project), Honda CD-200 1981, Triumph Tiger (project) Honda CD-185 (pending project)
    aliatif777's Avatar
    Jul 2010
    22
    165
    Anyone?
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    I think kick spring is broked
    aliatif777's Avatar
    Jul 2010
    22
    165
    Does it really cost 3k to change a spring? The bike starts and runs perfectly
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    there could be three reason
    1)the tooth type design which connect kick lever with shaft is worn up
    2)the shaft is broken from some where
    3)the spring inside the engine is brokem
    solutions
    1)the tooth type is worn it will be only repair in liaquadbad block 2 bike market's back street there are some mechanic that changes the design of shaft by grinder in desi mechanic language (palle bante hai)
    2)if shaft broken from some where there is no solution you need to get it welded it the breaking point is reachable if not full engine will be opened as kick shaft is loacted at the bottom of engine in that case use self starter to start bike unit your engine requires overhaulding
    3)inner spring broken it the most dangerous part it can't be repaired some mechanic installs outer spring but I am not sure about that it will work on cd 185 or not
    aliatif777's Avatar
    Jul 2010
    22
    165
    Quote Originally Posted by saboor73 View Post
    solutions
    Well the bike starts with it, the problem is when it starts the kick stays down makes a noise, I had to tie it so it doesn't go down, when the bike is not on the kick tends to stay up if I pull it from my hand upwards. So if the spring is damaged, its not possible to change it?
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Quote Originally Posted by aliatif777 View Post
    The situation you are asking shows that inner spring is broken and for changing spring complete engine will be openened
    Some machanics fix a spring at the outer side of the engine and kick go up automatically if you need pictures tomorror i will post them because right now the bike is unavailable
    aliatif777's Avatar
    Jul 2010
    22
    165
    Quote Originally Posted by JUNOON007 View Post
    Kindly do show me the pictures please asap, I spoke to my own mechanic, he said it would be changed by opening the crank case of the motorbike, but he isn't free for a week, I'll use this sort of tweak till then.
    aliatif777's Avatar
    Jul 2010
    22
    165
    Anyone else using the spring on the outerside?
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Tomorrow INSHALLAH i post pictures
    aliatif777's Avatar
    Jul 2010
    22
    165
    Thanks, waiting
