@taha66 Bro first make up your mind.There is literally no comparision b/w pridor and Piaggio.Piaggio is 125cc while pridor is 97cc
Fuel Economy:
WHen it comes to economy Pridor is the obvious choice with fuel avg or 60KM/L+ at speeds of 50km/hr..No less than 50km/L at speeds over 70km/hr.
Piaggio around 45km/hr max at 60 km/hr cruise.
MPG quotes are for standard factory mixture setting.
Comfort:
Both are comfortable rides in their respective class.Pridor is the most comfy ride in Honda's lineup.
Resale:
Pridor resale aint good.Piaggio enjoys better resale but obviously not on par with CG..
Used pridor/piaggio with low miles is recommended(but finding a clean ride is tricky)
Top and comfortable cruising speed:
Pridor can be stretched till 100km/hr for a slim dude with under 70 KG weight.I maxed out 95km/hr once and i am bulky 88Kg.COmfortable crusing(soundless0 is around 50 and easily bearable at 70..ABove 80 usual engine whines.Max constant cruising speed 85km/hr.
Piaggio
No idea.Owners can explain better.Theoretically it should clock 110 with ease with comfort cruise around 70km/hr.
Quality:
I bought CD-10 in 2012.So far it has clocked 16k kms without any problems.No issues whatsoever.The bike has plastic rear fender/side covers/headlight and every thing else is metal(makes up to 90% metal) so no issues here.Same is the case with every local bike in Pakistan.
It basically depends on how you ride and maintain your bike.If you are good at it then you can easily clock 70k kms in any good quality ride
