Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Like Tree4Likes
Thread: CG 125 Euro 2 jerks in 1st Gear after it heats up.
    mayo.asadullah's Avatar
    Dec 2014
    Lodhran
    25
    11
    Post CG 125 Euro 2 jerks in 1st Gear after it heats up.
    my bike makes cracking sound when i apply first gear and right after i try to release cluth it sounds like gurr gurr (gudd gudd) after that it start running normally just like every one else's does. I cant sort out this problem. i went to mechanic he told me to use high octane.
    vickytulla's Avatar
    Oct 2009
    8,419
    38
    876 Post(s)
    31 Thread(s)
    over heating due to lean feul and bad mobil oil.
    Quote Originally Posted by mayo.asadullah View Post
    akash190's Avatar
    Feb 2011
    Kharian
    22
    1,399
    8 Post(s)
    Quote Originally Posted by vickytulla View Post
    It's gearbox problem.
    A real driver knows exactly what's in his car.
    akash190's Avatar
    Feb 2011
    Kharian
    22
    1,399
    8 Post(s)
    As u know every euro 2 have that fault
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    (Copy/Paste)
    Clutch Judder
    It is due to offensive engagement of the clutch. Most of the drivers take it as a power of their machines. If the forward jumping of the bike becomes habitual then you have to think it as a clutch judder. You can feel the judder as an unsmooth engagement with vibration that causes the vehicle to suddenly jump forward. It is not at all result of worn out clutch plates. So dont change the clutch plates on the spot if somebody suggests you as remedy of clutch judder.
    Possible Causes and Remedies:
    Clutch judder is the result of misalignments or under tightened blots. Misalignment could be possible between plates, bearings and shafts, locks and pressure plates, spring seats and housing. Loose housing bolts, loose housing on flywheel, worn out shaft splines can also produce clutch judder. Sometimes engagement becomes jumpy because of distorted clutch plates also. In that case you don?€™t have any other options, change the clutch plates.
    The best car safety device is a rear-view mirror with a cop in it.
    Dec 2014
    Lodhran
    25
    11
    bro that was much informative...... but in winter i mean now a days she is perfectly working normal with gear and clutch....but in hot weather she is makes sound. does it have any connection with heating up.....
    Dec 2014
    Lodhran
    25
    11
    Quote Originally Posted by raja20103 View Post
    not every euro 2 has this fault....... i have rid others too.....
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    almost every euro m hai.. mary waly mn b the .ap LM oil use kro awaz khtm ho jy gee clutch ke ..
    Catch Me If u can...
    akash190's Avatar
    Feb 2011
    Kharian
    22
    1,399
    8 Post(s)
    Quote Originally Posted by Eur0_2 View Post
    almost every euro m hai.. mary waly mn b tha .ap LM oil use kro awaz khtm ho jy gee. clutch ke ..
    Grade? W?
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    Grade? W?
    lm 20w50
    Dec 2014
    Lodhran
    25
    11
    Bro, mere dost ke pass bhi euro 2 he lakin jab me us ki bike chalata hoon.... mjhe koi problem nazar nai atta..... any way LM oil kia cost pe hota he...
  12. #12
    Dec 2014
    Lodhran
    25
    11
    lm 20w50
    is it easily available, every where?
  13. #13
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    here in isb its price is 700pkr. yes every where
  14. #14
    Dec 2014
    Lodhran
    25
    11
    Bro ye kitne k.m k bad change krwana hota he
  15. #15
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    2k km tk chal jata hai..
  16. #16
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    I doubt yr Bike is running on rich Mixer. Check current condition of plug & post the pic.
    Exploring Machines is my Passion...
  17. #17
    syzeeh5's Avatar
    Oct 2014
    99
    Remedies???
  18. #18
    vickytulla's Avatar
    Oct 2009
    8,419
    38
    876 Post(s)
    31 Thread(s)
    Quote Originally Posted by syzeeh5 View Post
    Remedies???
    Good mobil oil and right mixture setting.
    (classic engine then use Havoline/Organic oil and dont go for synthetic oils)
  19. #19
    Dec 2014
    Lodhran
    25
    11
    Brothers, i got the handle of my honda 125 broken in an accident. i want to know the solution, either to buy new handle and suspension or to get it repaired from mechanic. i lost almost all the front part inclucing handle, meter, suspension, ainak, tire.
    is there any one in lahore who sells whole kit of (handle, fornt tire, suspension, meter, ainak etc)
  20. #20
    Dec 2014
    Lodhran
    25
    11
    Default I got broken fornt part of Honda 125 inclucing handle suspension.
