Page 5 of 5 FirstFirst ... 345
Results 81 to 85 of 85
Like Tree22Likes
Thread: LED Headlight for motorbike
    alizain5's Avatar
    Nov 2013
    Faisalabad
    26
    144
    Lightbulb LED Headlight for motorbike
    I recently installed chines headlight in my chines bike and very impressed with the result same like HID, but i found issue with the light was it cannot perform low beam function, it seems to be manufacturing fault because i found most of the other same headlights having same issue too, so i trace its power circuit and found two smd diodes faulty, so i remove and replace them with 2 (1N4001) diodes that are very common. Now they perform low beam function with lower 3 leds and high beam function with all 6 leds. The diode with brown wire is for angel eyes (so called) or for two small led ( i replace these blinking leds with white ones).
  2. #81
    muhammedahmed2's Avatar
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    pics yar
  3. #82
    alizain5's Avatar
    Nov 2013
    Faisalabad
    26
    144
    Please upload pictures, and kindly mention your expense on it.
  4. #83
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    hi
    was it directed toward me ?
    couldnt get it to focus ..
    Quote Originally Posted by alizain5 View Post
  5. #84
    AkhlaqAhmed's Avatar
    Jul 2012
    118
    2 Post(s)
  6. #85
    Jul 2012
    118
    2 Post(s)
Tags for this Thread
