Results 1 to 13 of 13
Thread: what is logic of rectifier
    muhammedahmed2's Avatar
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    Default what is logic of rectifier
    hello guys this is my first thread.I have Yamaha junoon yd 100 2009 model.Recently I installed 7.2 ah battery but was facing issue of charging....took it to Electricians he said kay rectifier double lagay ga....at the time i didn't know the definition of rectifier which i came to know know as "an electrical device which converts an alternating current into a direct one by allowing a current to flow through it in one direction only". and i went ahead with installing double rectifier...at the time battery felt like it was being charged but now after a few days its not charging....took it back and had the original setup installed back with just one original rectifier. now i spoke to another Electrician he said that original charger will need coil rewinding....now i just wanted to ask pakwheelers if they have ever installed bigger battery and how they dealt with charger problem i need a fool proof solution before I waste money again..
    Similar Threads:
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Why did you need a bigger battery?
    Rectifier charges the battery and stock rectifier will work fine as long as the battery is of same power as it came stock. When you put in a bigger battery you are asking the rectifier to do more work than its capacity. It is like using a pickup to pull the load of a Shehzor truck, if you get my point. So the solution is using additional rectifier. But again since coils on the bike are stock so you will need coils than can aptly provide better current flow now that you have more traffic going through it. Long story short, better keep it stock.
    I hope @imranbhatti comes across this thread and shares his view, an expert on the tpoic.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    WOW thanks bahi for the explanation ..by coils you mean ignition coils or something else....bahi program is to install 125 cdi,honda deulex ignition coils if i can find denso ones....i installed bigger battery only because program is to install led everything....led headlight,meter,indicators,backlight,led projector..i know i really dont need it because leds consume low amount of power.but still..and also i installed led headlight on bicycle so using motorcycle for that...as dry battery is quite heavy...but if i cant find solution for charging then eventully will have to fit stock battery
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    You can get the LEDs installed with the stock battery. Even if you can get the bigger battery and rectifier it would not perform as good as the original setup so better get back to stock, my suggestion.
    ahmed2396's Avatar
    Dec 2011
    36
    2,320
    5
    55 Post(s)
    7
    The alternator puts out an alternating current, and the rectifier simply converts the A/C output in to a D/C voltage that the bike can use or store in the battery. e.g a car came with 45AH battery from factory and owner puts in 70AH, fool people think that larger AH battery will provide more power but donot know that the alternator and rectifier has to work twice hard so it is best to use the battery which came from factory.
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    okay sahi ha good hogya ma phir stock battery naye aik leta hoon which one is best volta or any other company and what about calcium gel ones...if i can find battery with same amperage of original one should i buy calcium gel one..is it better is is it more fazool khap?
    ArshadXaidi's Avatar
    Sep 2012
    26
    494
    3 Post(s)
    original setups is fine i installed 7.2ah battery in my bike Jialing 70 electrician installed desi circuit which gradually weaken battery performance hence battery died in 4 to 5 months so i remove his jugaar circuit and stick it with original setup in desi setup electrician installed rectifiers and big capacity capacitor which boost charging current and hence these lead acid battery donnt bear high current charging so they die earlier than normal setup
    Proud Owner of Jialing Jh70 Model 2003
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    bus sahi ha im abandoning this program and will just buy new stock battery and have the original rectifier installed without any panga....exite meri 2+ years chal gai hai i think exite he *** ga phir.
    Sep 2012
    26
    494
    3 Post(s)
    if u wanna install bigger battery than install max 7 or 7.2ah dry battery with default setup it serve u well but purchase battery brand new on those battery there are date code on the top of battery near terminals
    Sep 2012
    26
    494
    3 Post(s)
    i installed FEEJI Battery 7.2ah on 14-03-2014 in my bike Jialing 70 as u know its self start i always use self start for starting my bike till date battery performing brilliantly i purchased battery from karachi electronics market and insisted shopkeeper to give me fresh stock i note down the date code of battery which tell that battery manufactured date in january 2014
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    Yes bahi that is what I'm doing I have a battery of 7.2ah and am when using stock setup battery not charging and weven after wasting money on double rectifier battery is still not charging how come your 7.2ah battery is being charged by stock setup
  12. #12
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    Liken now just abandoning everything and going with stock battery and stock setup and will install LEDs so power consumption is less and more brighter for my own and others safety at night
  13. #13
    amleonine's Avatar
    Jun 2016
    14
    Can we use capacitor instead of battery .. and is it harmfull or scare full for major problem
    Sent from my GT-I9192 using PW Forums mobile app
Tags for this Thread
