Results 1 to 5 of 5
Thread: Need help regarding CG 125
    Leo_The_King's Avatar
    Jul 2013
    30
    101
    2 Post(s)
    Default Need help regarding CG 125
    Hi respected members, m going abroad for a period not less than 6 months n my CG wud b all alone here, there is no one here who wud maintain it in my absence... So wat precautions wud u ppl recommend for its maintainance ? Like should i remove battery terminals? It is parked in back corridor of my house, this place is often wet, wat should b done to save its tyres? N some other do's n donts...
    Jul 2013
    30
    101
    2 Post(s)
    Bump
    Jul 2013
    30
    101
    2 Post(s)
    No one ???
    Chaudhary007's Avatar
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    • Remove engine oil (make sure it's completely drained)
    • Remove petrol from tank (make sure it's completely empty)
    • Remove battery and empty the acid and keep in a safe dry place (Can be used again)
    • Try to park it inside the house, outside in garage or galleries is not preferred due to adverse weather conditions and heavy rains these days.
    • Tires should be fine if you want you can remove the nozzles and air in them.
    • Make sure you cover it with proper covering sheets available in market for bikes, and they should be tightened up to prevent them from coming off.
    If you ride like there's no tomorrow, there won't be.
    Jul 2013
    30
    101
    2 Post(s)
    Thank u so much brother :-)
