Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Like Tree4Likes
Thread: suggestion needed regarding leaky and hard shocks
    asjdsm's Avatar
    Apr 2009
    30
    3,465
    57 Post(s)
    3 Thread(s)
    Default suggestion needed regarding leaky and hard shocks
    Hi,
    my 09 model thoooom shoks are leaking and are not up to the mark ..
    should i repair it ? are they repairable ?
    anyone share their experice and recomendation with it?
    what generaly needs to be repaired/relaced in it?
    which oil is used in them ?
    how much a set (4 shocks) of shock absorbers cost ?
    any good mechanic in rwp ?
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by asjdsm View Post
    Hi,
    shocks are repairable until their inner tubes are in good shape you would probably need new seals and shocks oil change
    biker99's Avatar
    Jan 2012
    Other
    57
    Hi,
    yes i recently repaired my chonda's front shock......! the right front shock was leaking so badly i gone to my nearest mechanic. he change the sock seal and clean the shock and re filled the oil and now its good.....!total cost of repair Rs:250 for one shock.
    actually repair depend on shock condition if its old leaking then it could be more damaged which mean more scratched....! more scratched shock leak again and again after some time..!
    in RWP there are many but go to the one most popular in rapeairing front shock..!
    Never repair Rear shocks...! I had very bad experience of rear shock repair...! one my chonda's rear shock was leaking and i gone to mechanic asked me for repair i gone to commetie chock and ask for repair it then he opened the shock and further there was no opening to shock absorber then his real face "hatora mechanic" comes in he cuts its opening with grinder/cutter and then drain out the oil inside it and put new seal and fixed it back with hammering and no oil filled....!!! then i asked why you not filled oil he said oil is not necessary then i said if its not necessary then why was it filled with oil.? he has no answer for it......! then i dis-heart with that and thought that will never open back shock again...! if its leaking oil its ok just clean it no need for opening....!
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Front shocks are easily repairable. If they are leak, you can just buy new fork seals at a nominal cost and fill them up with hydraulic oil (or power steering oil) , and they'll be good to go.
    Do you also have leaking problems on rear shock absorbers ??
    Riders on the storm ... literally.
    asjdsm's Avatar
    Apr 2009
    30
    3,465
    57 Post(s)
    3 Thread(s)
    yes rear shocks are also leaking.
    Quote Originally Posted by abobobilly View Post
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    There are several tutorials available at YouTube for refilling oil filled rear shock absorbers. I have never done that but people suggest replacing the rear ones instead.
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Dear Ahsan Ullah bro better option change only shocks absorbers with new ones & save your money+yourself from hathora,s mechanics they are easily available separately in parts market
    asjdsm's Avatar
    Apr 2009
    30
    3,465
    57 Post(s)
    3 Thread(s)
    hmm
    front shocks were refilled and seals changed but afte 1 year they agiain leaked..
    what should be the cost of shocks ?
    seems like front are different then the rear one
    Quote Originally Posted by hamikhan View Post
    qwertypoiu's Avatar
    Feb 2007
    29,128
    153 Post(s)
    2 Thread(s)
    Instead of wasting money and time just buy original new shocks and live a trouble free life for years.
    RIP
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    That means the seals you have used weren't of good quality. Better buy brand new genuine seals, which cost a little extra. (The ghatiya quality one costs barely Rs.50-70).
    And yes, Font forks are different than the rear shock absorbers.
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Ahsan Ullah khan for front shocks shock absorbers are not available they can be refilled or repaired you can change only shock absorbers with rear ones only
  12. #12
    silentplx1's Avatar
    Apr 2015
    23
    15
    Friends Main ny new brake shoe dalwaye hain aj subha but full tight b ki break but kam lagti hy. Hub ko sleve lagny wali hy i think. Koi friend ye bta dy ga k front nd back tyre ki sleve kitny tak lag jaye gi???
  13. #13
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Quote Originally Posted by silentplx1 View Post
    Dear thora wait kero leathers kay ghisnay ker adjust honay ka kutch din tak brake khud he set ho jayee gee
  14. #14
    silentplx1's Avatar
    Apr 2015
    23
    15
    Bro Nut Full tight kia hy. brake lever grip k sath lag jata hy phr bhi brake nahi lagti...
  15. #15
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Pehlay Mujhay yay batao k brake shoe change keranay say pehlay brake theek lag rahee thee k nahin?
  16. #16
    silentplx1's Avatar
    Apr 2015
    23
    15
    Nahi... SAme issue... POrany brake shoe b lay k aya ho. woh full use nahi howay.. around 40% use howay thy k Brake adjustment nut he end par chla gya or tight nahi hoa...
  17. #17
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    To phir dair kis cheez key hay silentplx1 dear fooran sleeves lagvao donon wheels key
  18. #18
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Quote Originally Posted by biker99 View Post
    One year ago my bikes rear shock leaked then i go to kharidia he open it with the help of kharad machine changed the seal fill new oil and then close this with the help of kharad machine and it looks like original its working perfectly till now
    in sargodha he is very famous for shock reparing
  19. #19
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    You need to fill oil in rear shock absorbers. It's not rocket science. Many videos are available on YouTube.
  20. #20
    asjdsm's Avatar
    Apr 2009
    30
    3,465
    57 Post(s)
    3 Thread(s)
    refiled oil in front shocks.,. from mechanic.. and also replaced some bearing type of thing .forgot its name .. it was where the front handle bars support goes through .. cost was 150 rs +100rs for japani seals
    total cost 500 (for labor + oil (20w50 caltex engine oil used ) + replacing ignition switch + some other minor work )
    total cost 750 ..
    mechanic placed a 13 number nut at the top of the spring .. he said spring is short ...
    it was easy task just requiring 8 nmber L allan key .. and 22 number gooti for openig the rod..
    one of the rear shock is a bit leaky..
    result : though much improved then previous condition but no where near soft/comfortable as it used to be before getting leaky...
    cost of new shocks :
    front 2100rs for future (was b/w 1800- 200 for others , 3k for atlas one )
    rear 1200 for future 1800 for atlas
