Results 1 to 17 of 17
Like Tree3Likes
  • 1 Post By hamikhan
  • 1 Post By scarfase
  • 1 Post By Chaudhary007
Thread: Bike Chamber
    imrd.rd's Avatar
    Nov 2014
    Chakwal
    26
    256
    2 Post(s)
    Default Bike Chamber
    Main ny Honda 70cc ka engine oil change keya hy aur bad main jo nechy net hota hy wo bhot zeyada tight kr deya hy ab wo leking kr raha hy iska koi hal hy???
    Chaudhary007's Avatar
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Quote Originally Posted by imrd.rd View Post
    Is the nut slip ? Or did it break inside when you applied force ?
    Let the bike cool down and by using 17 number Ring pana/chabi open it anticlock wise.
    If the condition of the nut is fine (i.e it edges have not become flat) than you should be able to open it.
    Is the oil really coming out of the nut ? My CG's magnet seal was leaked and it looked like the oil was leaking from nut.
    Change the nut if it's condition is not good.
    Still if you are not able to open it i would recommend mechanic they have different tools for these types of stubborn nuts
    If you ride like there's no tomorrow, there won't be.
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    mera bhi leak ho gia that nut slip honay ka baad..
    kisi mechanic ka chotay na slip kar dia tha..
    us ma ma na kharadia sa baray size ka nut lagva lia tha.. but naya nut laganay ka lia chorian banani parthi ha us ja engine case ma .. jis s a kafi kachara ikata ho jatha ha.. us ka lia muja clutch wali side ka case ko kolna para oil filter screen change ki our sara kharad maal nikal lia warna engine ka kabara ho jana tha.
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Remove the nut and take it to cobbler ask him to make a leather washer for it. Put the nut back and tighten it. Leakage will stop for sure.
    Help others so that u can be Helped
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    leather ka washer faida tab da ga jab nut our case ha hole ki choria theek hon..
    Quote Originally Posted by archon2001 View Post
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Quote Originally Posted by asjdsm View Post
    If they both are ok then whats the use of any washer except the 1 came with bolt.
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    every mechanic remomended it so i shared it.,
    hamikhan's Avatar
    Jun 2014
    Other
    1,261
    39 Post(s)
    Bhai go to any kharadia & ask him k over size moose pher do wo app kay wahin kharay he sab ok ker day ga only 15 minutes job
    scarfase's Avatar
    Dec 2013
    139
    6 Post(s)
    some time by tightening too much engine chamber gets hair line crack, check it properly weather nut is slip, chamber threads are slip or hair line crack.
    imrd.rd's Avatar
    Nov 2014
    Chakwal
    26
    256
    2 Post(s)
    Makinick ny kaha hy kAH pora cover change hoga
    aamirna97's Avatar
    Feb 2011
    129
    6 Post(s)
    CD 70 ka engine kitnay tak ka mill jata hy?lahore bilal gunj se milay ga ya kahin new he mill jaye ga?
  12. #12
    scarfase's Avatar
    Dec 2013
    139
    6 Post(s)
    Makinick kon say cover ka keh raha hai? yeh con sa cover hai jis se oil leak ho raha hai !!!! kiya cover se murad chamber ki toh nahi???
  13. #13
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    Mukamal ilaj yahi ha but.. Is ka lia pora engine kholna paray ga. Which means 3k tak kharcha. Is sa behtar ya ha ka Over size laga ka guzara chalaya jaya
  14. #14
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Cool
    Bike Chamber -1576386
  15. #15
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    any idea of its cost ?
    Quote Originally Posted by Chaudhary007 View Post
  16. #16
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Cool
    Rs2500 for CG Genuine AHL from Muhammadi Autos (One side)
    That makes 5k for both crank covers
    i am pretty sure for 70 it would be around Rs2k.
    Note: CG's Magnet cover (left) + Right cover cost me Rs1200 combined and add Rs100 for Gasket for the right one.
  17. #17
    imrd.rd's Avatar
    Nov 2014
    Chakwal
    26
    256
    2 Post(s)
    Thanx for All And asjdm bahi elaaj mokaml karwion ga
