Results 1 to 6 of 6
Thread: Motorcycle UD 70 Chain vibration
    sharraf's Avatar
    May 2015
    Default Motorcycle UD 70 Chain vibration
    Hey Guys,
    I recently changed the chain sprocket of the tire because the last one had gone bad. The bike chain from than on has been vibrating - making a zrrrrr sound when I ride it. When ever I spin the tire by hand I can see ripples in the chain. Further, when the bike is clutch free a sound like (tuck) comes after every rotation completes.
    I used to ride around 80kmh previously but now when I am riding only on 60kmh.
    Can you guys tell from your experience?
    alizain5's Avatar
    Nov 2013
    Faisalabad
    26
    144
    Check wheel alignment, sprockets and clean the chain with wd40 or petrol and apply oil.
    VCheng's Avatar
    May 2010
    Select City
    25,478
    7
    434 Post(s)
    4 Thread(s)
    Portions of the chain have stretched. You need a new chain.
    scarfase's Avatar
    Dec 2013
    139
    6 Post(s)
    just check if your front sprocket is fully tight
    ArshadXaidi's Avatar
    Sep 2012
    26
    494
    3 Post(s)
    check wheel alignment and also check rear sprocket does it have sharp teeth..... if it has sharp teeth you have to change sprocket do post pic of sprocket for further inspections
    Proud Owner of Jialing Jh70 Model 2003
    sharraf's Avatar
    May 2015
    Hey Guys
    Thanks for the replies.
    I checked the chain and sprockets. I think there is some issue with the wheel alignment. But chain and sprocket looks fine (chain is still oiled and new, and sharp edges on sprocket (back))
    Its been a week and the bike is running smooth (considering the roads of Karachi) I am driving am 80kmh.
    I think its fine and do not need a mechanic lookover at the moment as I am tight on budget
    Still thanks for the advice.
