Results 1 to 3 of 3
Thread: 70cc engine
    MatapatapAAA's Avatar
    Aug 2013
    144
    2 Post(s)
    Default 70cc engine
    I'll keep this short. I live in Lahore and I want to buy a second hand 70cc (can be a China 70cc, no need of honda etc ) to basically tear apart, put back together and learn about engines as a whole hands on. (Engine can be smaller or bigger then 70cc, just needs to be cheap. Under 6k and complex enough to learn something if I open it) and it needs to be working. If its from a motorcycle maybe I'll tear apart the gearbox and learn something there too.
    Any ideas ?
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    You should try scrape yard of you city
    Aug 2013
    144
    2 Post(s)
    In Lahore the kabari walay only deal in old vespas whenever I went. Although their engines are sufficient they are almost always seized up and the internals are rusted so the engine is basically useless.
Tags for this Thread
