Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By camry47
Thread: Usage experieince of Liqui Moli lubricant in Suzuki GD
    signode's Avatar
    Nov 2012
    99
    5 Post(s)
    Default Usage experieince of Liqui Moli lubricant in Suzuki GD
    Dear Friends;
    I have been using Liqui Moli lubricant SAE 20W-50 from start. I have noticed that in winter I changed the oil after 2000km. But in last oil change, mechanique told me that iff you will be continued to change the oil after 2000km, your engine will be dead because oil comes out very dirty. This time I byself changed the oil after 1500km. You can see in below images the difference between brand new oil and used oil 1500km. I was expecting that Liqui Moli will run more than 2500KM. Kindly share your experience. I am thinking to move to ZIC.
    I get the Liqui Moli in 1lit pack from Liqui Moli dealer at Muslim Town Mor Lhr.
    Usage experieince of Liqui Moli lubricant in Suzuki GD -1585585Usage experieince of Liqui Moli lubricant in Suzuki GD -1585586
    jadoon1992_vxlimited's Avatar
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    Sir 2500 kms is more than enough for liqui moly its a mineral oil. 1200 to 1400 kms is enough for 20w50 and that also in this extreme hot weather and air cooled bikes. @camry47 can guide you better
    people need to grow up sometimes and act MATURE !
    1747's Avatar
    Jun 2015
    Jhelum
    24
    216
    2 Post(s)
    Bhai use suzuki geniun engine oil its recomended for suzuki bikes
    Name:  ImageUploadedByPW Forums1434277114.682842.jpg
    Mirza
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    i am using havoline and i drain it at max 700-800 kms in summers and around 850-950 kms in winters. liqui moly can go upto 1200-1400 kms in summers. us se ziada chalana zulm hai
    camry47's Avatar
    Mar 2011
    2,340
    74 Post(s)
    Quote Originally Posted by jadoon1992_vxlimited View Post
    Thanks for the tag, LM 20w50 is mineral no one on earth should go beyond 1200-1400kms, after 1200kms it will start to burn and the quantity will become less you can examine yourself when you will drain
    Its useless to pour liqui moly if you only ride within the city and less than 50kms in a day
    Try to shift to ZIC HIFLO or FUCHS
    Remember we have single cylinder air cooled engines and our environment have scrotching heat, any mineral oil you will use going to reduce after 1000kms
