Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By amjad635
  • 1 Post By adeeljatoi
Thread: Honda cd70 problem in head
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    Default Honda cd70 problem in head
    My Honda cd70 model 2007 suddenly turned off while I was riding it,i took it to mechanic he checked & finally said head needs to be opened & will b repaired by Kharad work guy.i asked him if I can can replace with new parts h said that costs near 7K but if kharadya do It will b satisfactory work & cost around 2.5K if ring pistons are changed.i think something has to b done with valves too as mechanic says no kick pressure to start bike.plz suggest what is better?repair by kharadya or replacement with new parts.
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    consult another mechanic also don't trust one mechanic
    saboor73's Avatar
    Oct 2013
    10,548
    25
    350 Post(s)
    14 Thread(s)
    6
    25
    Community Votes: 1
    No compression can be due to thing piston ring broke or valve got bend in both cases head doesn't need Any kharidiya work you didn't ask mechanic what with kharidiya do to head
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    1st mechanic tried a lot to start bike,changed plug,put some oil in plug space,opened head big bolts but bike didn't start then he said it is kharadya work.i took it to 2nd mechanic he checked and said same kharadya work as there is no pressure when it is kicked.3rd mechanic said some problem with head valves or cylinder.‎Bike don't start at all,by kick or by running
    altisdualvvti's Avatar
    May 2012
    21
    1,965
    42 Post(s)
    Quote Originally Posted by wasf View Post
    How much this bike is driven and how was the engine condition before this issue.
    Sent from my GFIVE G10 mini using Tapatalk
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    Quote Originally Posted by altisdualvvti View Post
    I can't tell now how much bike has run so far as it is at workshop now but it is only driven by me since 2008 & runs good apart from some minor works time by time but for past 2 months I am feeling it consumes more petrol then before.
    The problem I faced today never happened before
    May 2012
    21
    1,965
    42 Post(s)
    OK but do tell me ones u get ur bike repaired
    adeeljatoi's Avatar
    Jan 2015
    Multan
    23
    18
    yes head ka kaam hi ha.
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    Solution
    Done! Problem was with valves one valve edge was broken, valves are replaced with new ones,kharadya guys work with valves adjustment.i also changed cylinder with ring pistons,gasket & plug,engine oil, filter.Bike is alive again running smoothly. I will upload some pics of valves etc.New head by Honda costs Rs 5000 but there was no need to replace as problem was with valves in the head which got repaired replaced by kharadya in Rs 800.
    wasf's Avatar
    Dec 2007
    38
    545
    36 Post(s)
    [QUOTE=altisdualvvti;4977945]How much this bike is driven and how was the engine condition before
    this issue.
    411594 is reading on meter.what should be reading after 800 km as mechanic told to change engine oil after 800km.
    Some weeks ago there was no pressure in kick when I tried to start bike in morning I took it to mechanic he did some work on side where kick is & told me to replace kick with new but bike run well after that until yesterday where it turned off while it was running
