Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: 70cc Head/Engine Heating.
    asad12347's Avatar
    Mar 2015
    46
    Default 70cc Head/Engine Heating.
    Hello everyone,
    I have unique 70cc, its been a month now i am feeling my engine is getting over heated. showed to the mechanic he said head is ok, tapid are working fine. we will have to open head to check piston/ring. i want to ask if anyone have idea about what is causing the over heating.
    mueen.uk's Avatar
    Sep 2015
    43
    83
    Change oil with kixx 10w40 it will b ok then
    mohsinwahhab's Avatar
    Jul 2013
    26
    1,133
    19 Post(s)
    change the engine oil to higher viscosity, try castrol 20w50
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    First what makes you think its overheating ? Extreme lean fuel mixture can cause heating issue did you recently got youe bike tunned with "petrol kam kardo" wali tunning?
    Hassan1991's Avatar
    Mar 2013
    20
    2,259
    37 Post(s)
    If engine oil's fine then check the oil pump......the easiest way to check it by losing the upper tappet cover and then starting the bike, after starting open the tappet cover and slightly lift it than see that it sprays engine oil form there or not.....if it is not spraying then your oil pump was not work right.
    asad12347's Avatar
    Mar 2015
    46
    1. How it can be oil issue as i am using GTX since 3 to 4 years in my other bike also never caused problem, and i change my oil on 1000KM.
    2. Yes I recently tuned my bike on Sat, but its third tunning after the heating. And i dont believe in "petrol kam krdo wali" tunning. Mai shoqeen ho 90 100 per ly kr jata ho kam petrol mai guzara nai hta .
    3. Normally 40 ki speed per chalao hardly 1 sy 2 km engine itna garam hjta ky you can't touch it. And sometimes it start smelling like overheated engine.
    4. Oil pump is ok, last checked at tunning on Sat.
    One more thing to mention my carburetor is not genuine, its lifan with 85main jet and 34slow jet. It has missing problem so i rejetted it about year ago.
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    if oil pump is ok and you are satisfied with engine oil also the mechanic
    then only thing remain that can be suspected for heating is chinese carb
    may be it has malfunctioned and is not providing right mixture to engine
    and engine is getting hot
    has the mechanic checked the spark plug? if it has crossed over 11k km change it
    asad12347's Avatar
    Mar 2015
    46
    Yes plug is ok.
    how to check carb? if i change with another, it will start missing, then have to rejet it.
    and my mechanic has advice to run the same, jb tk chalta h engine aisihi, farig hga to new carb or head daly gy matching ka.
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    which bike do you have and how much km on odo?
    i don't like chinese accessories at all lifan etc have very low quality
    and specially an component like carburetor they don't make these good
    an good mechanic will be able to read from spark plug condition weather
    carburetor is supplying right fuel mixture and if you have some good friend
    you can borrow carburetor from his bike and give a try if engine gets hot
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Check folat height if its too low engine could heat up
    asad12347's Avatar
    Mar 2015
    46
    I have Unique 2013 (second hand) 27K done, engine repaired 1, head repaired twice.
    you know where to find genuine unique carb? i was thinking to buy Saz carb now, its better than lifan and other but if i can get genuine it will be great.
  12. #12
    asad12347's Avatar
    Mar 2015
    46
    how to check float level? no idea about it.
  13. #13
    Hassan1991's Avatar
    Mar 2013
    20
    2,259
    37 Post(s)
    Problem in pulser and coil or the wrong timing also causes over heating.
    The first step towards knowledge is to know that WE are IGNORANT
  14. #14
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Quote Originally Posted by asad12347 View Post
    than it is very possible some thing wrong inside engine in fitting
    most mechanic are idiots they can't rebuild engine properly and your bike
    is opened three times 1 time engine and 2 times head repaired
    you can buy atlas honda genuine carburetor but i don't think now carebutor
    can only be taken as suspect after what you told for engine condition
    let me tell you case of cd70 2009 model of my relative he bought it used
    mechanic suggested engine repair and after repair his bike's engine was getting
    heat up after some use and missing so eventually he sold the bike
  15. #15
    asad12347's Avatar
    Mar 2015
    46
    i will check coil, timing is ok already checked.
    when i purchased it engine was dead so repaired it around 15k KM (that was the reading meter showing dont know if it was actual), then everything was good, even i have touched 110-120. the heating problem started in mid Dec.15, i showed to different mechanic 1. said head and clutch plate are gone, 2. said ky wall tery hgae h and piston jam lag rha h or muskil sy 1 sy 2 hafty chaly gi. (still running) 3. said oil is jaali and carb mai khachra h. (changed oil twice and tunned aswell no effect)
    i will not sell it.
  16. #16
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    i will not sell it.
    wall = valves if valves are bent engine would leal compression you engine performance will decrease to great extent plug will be full of oil (unburnt smoke actually)
  17. #17
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Open carb the bowl that holds fuel is float bowl
  18. #18
    asad12347's Avatar
    Mar 2015
    46
    I called my friend and showed him the bike, he said problem is with carburetor, head and carburetor are not matching. You rejetted it in hot weather it was fine as now weather is cold its not matching with head and causing heating. On other hand head is also weak and losing its performance.
    His advice is not to do anything and run it till it completely goes down then repair complete engine at zero with new piston, new head and carb.
    1 question do hot/cold weather matter's?
  19. #19
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    i will not sell it.
    i suggest go to honda antenna mechanic or warranty mechanic not all mechanics
    are good even here but alteast they are better than any road side mechanics so
    i suggest go to him tell him all details lets see what he suggest
    after what you are telling now you have idea of what i was saying in my post
    most mechanics are idiot as you told three mechanics told three different
    possibilities
    and i think you should try thinner oil like 20w40 and check if it helps
    clutch plates are worn out when you feel clutch slippage and bike feels
    heavy on speeds like 60 and above and it takes time to go higher speeds
    if you are not in mode of selling it than brother you search for good mechanic
    try honda's mechanic as i said
  20. #20
    asad12347's Avatar
    Mar 2015
    46
    where will i find honda mechanic? or any good recommended mechanic?
    i will visit another one tmrw near Johar, he is a good one in alteration, let see what he says.
