Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: 70cc Head/Engine Heating.
    asad12347's Avatar
    Mar 2015
    46
    Default 70cc Head/Engine Heating.
    Hello everyone,
    I have unique 70cc, its been a month now i am feeling my engine is getting over heated. showed to the mechanic he said head is ok, tapid are working fine. we will have to open head to check piston/ring. i want to ask if anyone have idea about what is causing the over heating.
  2. #21
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by asad12347 View Post
    I called my friend and showed him the bike, he said problem is with carburetor, head and carburetor are not matching. You rejetted it in hot weather it was fine as now weather is cold its not matching with head and causing heating. On other hand head is also weak and losing its performance.
    His advice is not to do anything and run it till it completely goes down then repair complete engine at zero with new piston, new head and carb.
    1 question do hot/cold weather matter's?
    Your friend is wrong hot or cold weather it does matter much for carb to head fitting
  3. #22
    asad12347's Avatar
    Mar 2015
    46
    and i just checked the oil bottle its 20W-50 GTX
  4. #23
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    The old designed cd70e engine is more than happy with 20w-50 don't worry about oil
  5. #24
    asad12347's Avatar
    Mar 2015
    46
    Quote Originally Posted by saboor73 View Post
    then i guess the problem is with the Carb.
    one question i have in mind if its a problem with piston or ring, does the bike goes to 100 110? runs for a month & half?
