Results 1 to 7 of 7
Thread: Engine noise after oil change
    alizain5's Avatar
    Nov 2013
    Faisalabad
    26
    144
    Default Engine noise after oil change
    Last month i change engine oil to Shell AX5, previously i was using Shell AX3, i noticed that engine noise increase with AX5. I bought the oil from shell pump which is very reputed in faisalabad. I don't know how distinguish between original and fake oil. Please share if anyone knows how to check visually or another way.
    sarmad13's Avatar
    Apr 2013
    31
    Quote Originally Posted by alizain5 View Post
    What is the viscosity difference of both oils ?
    what is the millage of your car and its model ?
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by sarmad13 View Post
    Viscosity of both is 20w-40
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Quote Originally Posted by saboor73 View Post
    the shell Ax3 is 20w50 and Ax5 is 15w40 so extra noise is obvious
    as shell Ax3 is thick so you listen less noise and Ax5 is thinner you
    listen noises which i think you should not worry about a little bit sound
    change is expected when switching to thinner oil if you are not liking
    bikes performance with this oil then switch back to Ax3
    its really hard to distinguish between genuine and fake best you can do
    is buy from reputed big engine oil trader in your city avoid local shops
    and if you can find contact numbers on shell site contact them and ask
    for authorize dealer in your city
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by amjad635 View Post
    Sorry for the confusion shell ax5 is available in two viscosity
    Engine noise after oil change - images?qtbnANd9GcSeE DfPayFM28cZw7gsU2pTpe yKpVseJIW1LzYYFsmyrsUc55gdZp6Bv5uQ
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Saboor i have not checked shell engine oils from long time
    its good if its now coming in 20w40 as well
    alizain5's Avatar
    Nov 2013
    Faisalabad
    26
    144
    Viscosity of AX3 was 15-40W mentioned on the label I used. I already done 28k+ on odometer. Now I really think to change back to AX5 (20-50W). AX3 feels much thinner don't know how hard it perform when engine is hot. Shell claims that it performs 20 to 30 percent more as compared to AX5.
