Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By saboor73
Thread: Bike Pick Issue
    f4fraz's Avatar
    Dec 2013
    34
    672
    17 Post(s)
    Question Bike Pick Issue
    Asalam Alaikum
    how r all?
    mera qst hay ke 70cc bike ke speed aur pick kam hoi hay jesy bike dabi dabi si hay.
    kya kya possibilities ho sakti?
    twining
    oil change
    clutch plates
    any other issue
    Please tell ur experience with best solutions to get better to pickup. agar uper wali koi option kam a sakti to plz detail se guide karen.
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Most probably
    Worn out spark plug
    Air fuel mixture set a bit lean
    f4fraz's Avatar
    Dec 2013
    34
    672
    17 Post(s)
    Quote Originally Posted by saboor73 View Post
    Most probably
    Worn out spark plug
    Thank you SABOOR
    What I decide after ur post is:
    apply tuning
    change spark plug
    change engine oil
    change air filter if needed
    all small things will be covered in tuning like tappet setting, mixture setting, fuel setting etc
    f4fraz's Avatar
    Dec 2013
    34
    672
    17 Post(s)
    2 more qsts.
    Spark Plug:
    In past it was as get as used. which spark plug to use in 70 from now?
    Engine Oil:
    I m thinking to use zic/any-good 20w50. Will it fine for 70?
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by f4fraz View Post
    2 more qsts.
    Spark Plug:
    Engine Oil:
    Spark plug is cr7 ngk
    Oil you need a zddp oil in cd70 and its replica
    mohsinwahhab's Avatar
    Jul 2013
    26
    1,134
    19 Post(s)
    bhai ager aap ko tuning karaney key baad yeh masla mehsos hwa hai to mechanic ney aap key tappets zyada tight kar dye han thorey sey loose karwa lo
    Asalam Alaikum
    how r all?
    twining
    oil change
    clutch plates
    any other issue
    f4fraz's Avatar
    Dec 2013
    34
    672
    17 Post(s)
    Quote Originally Posted by mohsinwahhab View Post
    kya bhai ap ne pehly hi bori bana li.lol
    bhai mene 2 3 sal se tuning nye karwai kabhi need nye pari.
    abi to karwani hay.
    Jul 2013
    26
    1,134
    19 Post(s)
    to bhai karwao na tuning phir intazar kis baat ka hai
    tuning karwa kar share karo bike kasi chal rhi hai
    abi to karwani hay.
    f4fraz's Avatar
    Dec 2013
    34
    672
    17 Post(s)
    tuning se dar nye lagta saab
    time nikalny se lagta hay... lol
    yehi to masla hay time hi nahi nikalta
    altisdualvvti's Avatar
    May 2012
    21
    1,966
    42 Post(s)
    Thank you SABOOR
    apply tuning
    change spark plug
    change engine oil
    Use zic oli m5 20-40 change the spark plug to NGK and tune the bike from a good mechanic and u r good to go.
    Share some details of your bike make model mileage engine condition.
    Sent from my INFINIX-X551 using Tapatalk
    f4fraz's Avatar
    Dec 2013
    34
    672
    17 Post(s)
    Today tuned 70
    zic 20w40
    c7 ngk
    air filter
    clutch outer spring
    carburetor joint seal
    some other minor parts
    after doing this all just 1 more issue was there and that was kick
    kick foot holding liver is 80% free and foot didnt grip over it and slip.
    he force me alot but i was in mood of change it any other time.
    due to that reason the bike starter was not getting good power but after a lot try it starts.
    but i also feel there is some kick force issue too when will repair kick then will analyse and if there will some tappet or clutch tighten issue, it will be solved by the guy.
    the ride is smooth, sound is polite.
    will check the pick later too.
    if anyone have any ideas or suggestion about kick go down a little tighten or can say no force/response found while kicking.
    in real when we apply kick it go down by jurking, feels like tik tik tik
    plz share ur good thoughts.
