Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: 70CC Missing
    asad12347's Avatar
    Mar 2015
    46
    Default 70CC Missing
    Hey Guys, Hope all are good?
    I am facing carb issues. Built complete engine with New Head+Cyclinder (78cc) added new Saz Carb (hero) with 85MJ & 34PJ. then bike ki race nai kam ho rhi thi, went to a mechanic he adjusted it. i drove it to 600KM after oil change we thought to give engine a speed try. it was bad.
    bike shows missing at pick. we tried changing carb but no good. 4th gear mai race chor kr uthao to aisa lagta h sara petrol khtm hgya, jhatky mar kr set hjti h. almost wasted 4 5 hours, no luck.
    then we remove air filter its not showing missing now. but bike is getting heatup. and i dont want to run it without air filter.
    any advice what will be the cause? went to 3 diff mechanic all are saying carb is not good. (changing carb not solving problem)
    1 said to get a original Hero carb from Honda dealers, i am worried if i bought it and still no use, then!
    please can anyone suggest what will be the issue?
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    cdi or coil is giving the problem...have you changed them?? or the mechanic clean the coil which is located in side the magnet?? probably your bike is missing current
    asad12347's Avatar
    Mar 2015
    46
    Quote Originally Posted by Hassan1991 View Post
    I asked him about current, he said current is fine. didn't check the CDI though, will replace it with a new one.
    i have put the air filter back, bike is showing missing at pick. one thing i am worried about is the heatup. on normal ride at 40km, engine get really heatup.
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Quote Originally Posted by asad12347 View Post
    What about the condition of engine oil?
    Amount of petrol is more than the current that's why bike misses and heated up change the jet of petrol with smaller one
    The first step towards knowledge is to know that WE are IGNORANT
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Your bike is hero 70 right?
    asad12347's Avatar
    Mar 2015
    46
    Changed oil 2 days back after 600KM, Nah its not Hero. carb is Hero of Saz company.
    its main jet is 85, replacing jet with a smaller one? missing or tu nai bhar jaegi?
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Check if chock is functioning right and not working all the time that airfilter you mention clearly indicate chock is pulled
    asad12347's Avatar
    Mar 2015
    46
    Quote Originally Posted by saboor73 View Post
    ok will check the choke, but i dont think its choke issue, as we have replaced 3 to 4 carb from other bikes, problem was still there.
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Community Votes: 1
    stock engine slightly loses strength by pulling airfilter without increasing petrol because air goes in excess amount now in your case bike start working fine when you pull airfilter so petrol goes in excess amount or amount of petrol is too low
    first ask mechanic than increase petrol by "jet slie" if problem increases then ask him to decrease it
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    you have change the carb with many bikes it shows that problem is not in carb then the last thing which left is current
    asad12347's Avatar
    Mar 2015
    46
    removing airfilter was effecting the speed, without air filter it was hardly reaching to 60, with air filter (not touching carb setting, only fitted filter back) its easily going to 80 but with missing at pick ups.
  12. #12
    asad12347's Avatar
    Mar 2015
    46
    yar but mechanic is saying current is ok. has shown to 3 - 4 diff mechanics all are saying carb is not matching with engine.
  13. #13
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    bike misses at all rpm or only when your increase rpm
  14. #14
    asad12347's Avatar
    Mar 2015
    46
    from O to 50/60 changing gear its smooth. phr release accelerator or race kam kro speed kam krny ky lia or dobara race do to aik dam ghoot jati h jaisy koi rook rha ho bike ko, phr jhakty mar kr uthy gi or araam sy 80 touch krly gi.
    or gear change kia second mai uthae to same masla hta h.
  15. #15
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Means higher miss in higher rpm try to install its original if you can and did you check spark plugs if not then check if its black then there's excess petrol
  16. #16
    asad12347's Avatar
    Mar 2015
    46
    I don't have it original carb, spark plug is ideal, means brown. Not black.
  17. #17
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Brother try to increase and decrease the petrol by "jet slie".......let see what happens
    I faced this problem many of times many and always the fault is current but may your case is different
  18. #18
    asad12347's Avatar
    Mar 2015
    46
    Ok will check today evening by changing silde position. Them lets see.
  19. #19
    asad12347's Avatar
    Mar 2015
    46
    @Hassan1991
    Thanks bro, my problem is almost over, just facing one issue, I changed the CDI and raised Slide pin 1 notch upside, means its now on ideal position (center) now its running smooth.
    but race ab bhar gae h dobara lykn phaly sy kam h, i am thinking to change its main jet to a lower number. any advice how to set its race?
  20. #20
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    @Hassan1991
    Why you want to change its jet??
    You can adjust race from the side screw
