Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
Thread: 70CC Missing
    asad12347's Avatar
    Mar 2015
    46
    Default 70CC Missing
    Hey Guys, Hope all are good?
    I am facing carb issues. Built complete engine with New Head+Cyclinder (78cc) added new Saz Carb (hero) with 85MJ & 34PJ. then bike ki race nai kam ho rhi thi, went to a mechanic he adjusted it. i drove it to 600KM after oil change we thought to give engine a speed try. it was bad.
    bike shows missing at pick. we tried changing carb but no good. 4th gear mai race chor kr uthao to aisa lagta h sara petrol khtm hgya, jhatky mar kr set hjti h. almost wasted 4 5 hours, no luck.
    then we remove air filter its not showing missing now. but bike is getting heatup. and i dont want to run it without air filter.
    any advice what will be the cause? went to 3 diff mechanic all are saying carb is not good. (changing carb not solving problem)
    1 said to get a original Hero carb from Honda dealers, i am worried if i bought it and still no use, then!
    please can anyone suggest what will be the issue?
  2. #21
    Hassan1991's Avatar
    Mar 2013
    20
    2,268
    37 Post(s)
    Two screws are located outside the carb one of them are for race
    The first step towards knowledge is to know that WE are IGNORANT
  3. #22
    asad12347's Avatar
    Mar 2015
    46
    Quote Originally Posted by Hassan1991 View Post
    Yes, we set the petrol screw first. then race waly ko kam krty h tu aik jaga akr race kam nai hti, beshak pora screw bhi kholdo.
  4. #23
    Hassan1991's Avatar
    Mar 2013
    20
    2,268
    37 Post(s)
    Quote Originally Posted by asad12347 View Post
    Accelerator ki wire check kari theek hai accelerator ka necha setting hoti hai usa set kro vo kharab ho gii
  5. #24
    asad12347's Avatar
    Mar 2015
    46
    cable bhi thk h, grip waly screw ky setting bhi check krli, no good.
  6. #25
    Hassan1991's Avatar
    Mar 2013
    20
    2,268
    37 Post(s)
    Masla wire sa hi hai keu ka "slie" ek jagha pa aa kr stuck ho jati hai isi vaja sa screw set krna sa bhi kam nae hoti
  7. #26
    asad12347's Avatar
    Mar 2015
    46
    Then i will change cable with a new one. lets see...
  8. #27
    Hassan1991's Avatar
    Mar 2013
    20
    2,268
    37 Post(s)
    Don't change cable right now brother first be sure
    Said mechanic that check it's grip nut and also the cable
  9. #28
    asad12347's Avatar
    Mar 2015
    46
    Hi Bro, checked the accelerator cable its fine, Showed to mechanic he's saying no problem with the cable.
  10. #29
    Hassan1991's Avatar
    Mar 2013
    20
    2,268
    37 Post(s)
    Then brother slide is not matching the jet means it is not touching the jet when accelerator is ideal
    Put the slide notch at the second point......start counting from top
    So the slide goes downwards more
    Problem of missing is solved?
  11. #30
    asad12347's Avatar
    Mar 2015
    46
    Yes missing is gone now, showing excellent pick. I have first move the C clip on 2 position, no good then i have moved it to first point, still no good
  12. #31
    Hassan1991's Avatar
    Mar 2013
    20
    2,268
    37 Post(s)
    First!! Starting from the top....
    Race is how much...to irritating level
  13. #32
    asad12347's Avatar
    Mar 2015
    46
    Yes, its seem like ky apny race di hoe ho bike ko.
  14. #33
    Hassan1991's Avatar
    Mar 2013
    20
    2,268
    37 Post(s)
    Ap phir jet slide change kr loo dono match nae ho rha
  15. #34
    asad12347's Avatar
    Mar 2015
    46
    ok will go market tmrw for slide & jet, then lets see.
  16. #35
    Hassan1991's Avatar
    Mar 2013
    20
    2,268
    37 Post(s)
    You showed to mechanic what he's saying
    No doubt they no nothing
  17. #36
    asad12347's Avatar
    Mar 2015
    46
    yar i have shown to 4 5 diff mechanic, they all spend 5 6 hours with it, wasting my time and money for nothing. fed up with the mechanic now. trying myself. with your help missing is gone now (Alhamdulillah).
    Here mechanics are good for tuning only. the one build the engine has no idea, and other are saying we haven't face any issue's like this.
  18. #37
    asad12347's Avatar
    Mar 2015
    46
    Before the engine rebuild completely, i took suggestions from many people, all suggested to rebuild it and not go for the new bike (bht achi bni hoe h ap engine bnalo bht maza kry gi bike) now i understand the enjoyment. 3 weeks up still facing problems... ahh...
  19. #38
    Hassan1991's Avatar
    Mar 2013
    20
    2,268
    37 Post(s)
    Bhai mechanic to apsa zeyada muja bura lagta haien is leya ma kabhi gya hi nae mechanic ka pas ap khud carb khol ka dakh lo manually ka slide neecha touch hoti hai ka nae
  20. #39
    Hassan1991's Avatar
    Mar 2013
    20
    2,268
    37 Post(s)
    Rebuilding is not a problem I personally change mien bike piston head many times I also have problems many problems when bike having point but always sort out my self whether brick it or set it
