Results 1 to 8 of 8
Thread: Super Power CD70 bike wiring diagram
    Newbie Follow
    helemantk001's Avatar
    Mar 2016
    Default Super Power CD70 bike wiring diagram
    May anyone please help by sending SP cd70 bike wiring diagram...
    i tried too much on internet but could not found wiring diagram also workshop manual...
    Please help
    Hassan1991's Avatar
    Mar 2013
    20
    2,269
    37 Post(s)
    after searching on internet i found this
    You can tell me the problem may I can help.
    munnapk89's Avatar
    Feb 2012
    Rawalpindi
    122
    6 Post(s)
    Quote Originally Posted by Hassan1991 View Post
    This diagram corresponds to the earlier versions (70s) of 70cc and 65cc Honda motorcyles.
    I have done complete electric setup on a Hero 70 recently. I searched too but couldnt find anything related to what I needed. According to one of my guru g and I quote him,"Ye majay gamay model hotay hain, in ka na sar hota hay na payr, wiring diagram kis ne deni." Manual tau bhool hi jayain bhai.
    However, A little basic theory can get you through. Good Luck !!
    For those who dare, the future is in skies ...
    Hassan1991's Avatar
    Mar 2013
    20
    2,269
    37 Post(s)
    Quote Originally Posted by munnapk89 View Post
    Yep...there's no such manual which can give a completely guide however I had done complete wiring many of times never need a manual that's why I said him that he can tell me his problem.
    The first step towards knowledge is to know that WE are IGNORANT
    Newbie Follow
    afaque198's Avatar
    Jan 2012
    i have bought super power 2016. there were two fuse in battery my mechanic did some thing with fuse all wiring went dead accept its ignition head light plz tell me which wire to connect which so that i can turn everthing back on ..
    this wiring map is only showing one fuse
    Hassan1991's Avatar
    Mar 2013
    20
    2,269
    37 Post(s)
    Quote Originally Posted by afaque198 View Post
    Check the battery fuse our mechanics are awesome they remove the fuse and make them direct.Also Check the both Back and Red wires of battery may be they had came out from there socket.
    Newbie Follow
    sarimwahab7's Avatar
    Oct 2016
    head light not working can you give any suggestion, its work when i touch the head light from body
    Hassan1991's Avatar
    Mar 2013
    20
    2,269
    37 Post(s)
    Quote Originally Posted by sarimwahab7 View Post
    Did you use wire to touch??...from what I understand it looks like bulb neutral (ground) wire is breaked...to repair it open the head light lens and loose one head light bolt now insert the wire in that bolt tightened it and connect the wire to bulb holder.
