Results 1 to 9 of 9
Like Tree11Likes
  • 1 Post By d3vil
  • 3 Post By hash737
  • 1 Post By tucknoloji
  • 2 Post By Banoori555
  • 2 Post By d3vil
  • 1 Post By Banoori555
  • 1 Post By d3vil
Thread: Review - United Trail DT 125cc
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Lightbulb Review - United Trail DT 125cc
    Bike: United Trail DT 125cc
    Market Price: 95k
    Model: 2016
    Category: Dual Purpose Trail
    Engine: 125cc Single Cylinder 4 Stoke Air Cooled
    MAX Torque (N.m/r/min): 11.0/5500
    MAX Power (Km/r/min): 9.3/8000
    Gears: 5 (All Forward)
    Battery: 12V 7 AH
    Seat Capacity: 2 Person
    Starting System: Self & Kick
    Max Speed = 100km/h
    Break Front/Back = Drum
    Rim Size: Front - 21 Rear ? 18
    Weight: 120 kg
    Best Average Till Now = 35km/Lit
    NOTE: This bike is copy of Qingqi DP 150cc, Only Engine has been downgraded to 125cc rest each nut bolt is of the same bike. All reviews shared after Testing.
    Major Changes:
    Ignition Switch Key
    Engine
    Gear Shifting: All Forward
    Engine Performance:
    As above mention that it is the copy of the Qingqi DP 150cc so body weight is also same for 125cc engine. Comparatively 125cc engine of other Street bikes available in market it is low powered. (Power in sense of initial Pick), Even are high RPM at low gears, its output torque is very less which will give tough time on higher altitude. Trails demand higher power in the initial because when you do off road you are in low gears for quickly passing all trains of mud, rocks, water & heights.
    On Straight Road:
    Shifting of gear is smooth but if you give higher rpm in 2 or 3 complete bike will vibrate. Which is not an issue as chines don?t put balancer shaft in small engine to control vibration.
    On Higher Altitude:
    Carburetor need to be changed as bike start missing which we faced same issue with DP 150cc. (Use can use Carburetor of Delux 2006 Model)
    Electric Part Issue:
    As the quality of CDI is not good so better to change with Cg 125 (Grips need Replacement if you use Original one of Honda but if you want to put the same then, Search for Chinese brand)
    Tyres:
    Dual purpose Tyres, with very good thread will help you in Off Road-Mud & Rocks.
    Things Need Attention:
    Tuning is must from Expert - Other thing which need to recheck (Carburetor, Taped Adjustment, Oil Checking, Front Shock Oil Change & Setting, Break Leather Checking, Column Alignment, Chain Replacement with good brand, Complete body Inspection, Tight up all the nuts & bolts).
    Over All Review:
    Very Good Height, Self & kick both options are available. Light weight, easy handing, Round light with good focus on road. Not satisfy with the engine power.
    Review  United Trail DT 125cc -1678724Review  United Trail DT 125cc -1678725Review  United Trail DT 125cc -1678726Review  United Trail DT 125cc -1678727Review  United Trail DT 125cc -1678728Review  United Trail DT 125cc -1678729
    Similar Threads:
    hash737's Avatar
    Jan 2010
    1,073
    31 Post(s)
    for 95 thousand Rupees, they cant even align the rear light of the bike with rest of the bike.
    as this is a public thread and everyone is entitled to their own opinion, this is a very ugly ugly ugly bike.
    the quality of the bike in pics seems it would hardly serve the purpose of TRAIL bike.
    tucknoloji's Avatar
    Jan 2010
    35
    572
    22 Post(s)
    2 Thread(s)
    Tyres Brand name? .. Sprocket info??? Engine Mounts type??? Engine type?? Fuel tank capacity and any replacement option for tank?? Handle grips quality??? Chain number ???
    Sent from my HUAWEI G610-U20 using Tapatalk
    Banoori555's Avatar
    Jul 2013
    42
    356
    4 Post(s)
    Worth should have been around 33 k , seems to be costly item with less chances of promotion amongst people who know what a trail should be
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by hashsohail View Post
    Well regarding break lights a 20 lak rupee car lak this excellent feature in Pakistan
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by tucknoloji View Post
    Will add info dont you worry .... Regarding Tank replacement you can customize on any bike..
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by Banoori555 View Post
    33 k Bike in chine cost u around that figure, After importing (A WARM WELCOME FROM PAKISTAN CUSTOM) so dont forget them .....
    Banoori555's Avatar
    Jul 2013
    42
    356
    4 Post(s)
    Quote Originally Posted by d3vil View Post
    This brand has failed to attract clients due to unrealistic price against product quality , all dealers are found fooling people , where as due to very less registering of such bike at Excise office the reality can be unfolded , one can gather data about registering of such toys by worthy owners & its sale,or no of bikes plying on the roads may be 1 in thousands or even that can't be located, its even resale is scaring people against the price , a toy should be charged against its worth. People having streak of money may go for it IMHO
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Agreed...
