Results 1 to 8 of 8
Thread: Bike gets hot during Break-in (Running).
    ftb7007's Avatar
    Apr 2016
    Peshawar
    45
    3 Post(s)
    Default Bike gets hot during Break-in (Running).
    Solution
    I bought a Honda CG 125 today & after travelling for 2-3 km the bike gets really hot, Is it normal during break-in (Running)?
    chdemon's Avatar
    Sep 2012
    1,439
    43 Post(s)
    dont worry kuch nai hota, enjoy the ride.
    Quote Originally Posted by ftb7007 View Post
    Sent from Cultus Limited Edition... using iphone 6sss...
    hassantahir2's Avatar
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    It's the paidaishi bemari of Honda CG 125 Now a days. No need to take tension.
    Sent from my D2502 using PW Forums mobile app
    Four wheels move the body
    Two wheels move the soul
    k-four-nine's Avatar
    Jan 2014
    695
    27 Post(s)
    Brother, I'm no expert but I do know a fare deal about engines... And I'd say; Don't worry, the problem will vanish with the first oil change...
    A brand new engine does get very heat-up during break-in period... It's because there are so many metallic particles and shards inside the crankcase and transmission that move around in the oil and cause excessive friction... Hence you're witnessing unusual heating issue...
    After the first oil change, things will get a lot better in this regard as these particles will be flushed out with the oil...
    Just don't rev the engine excessively & stay under the speed limit as prescribed in the user manual and you'll be fine... Also don't rev the engine when idle... Stay under 5,000rpms... And do change the first oil at the right interval, maybe even sooner if your budget permits it...
    All the best...
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    CG Engine does gets very hot so its normal specially in city
    it gets this much hot that you will feel heat in your feet
    post911's Avatar
    Jul 2012
    Other
    189
    3 Post(s)
    I had a cg and did realise it was getting quite hot even at low rpm,
    Especially when the outside temp is around 40 degree,
    Because these engine are air cooled so the air it's getting is super hot,
    Try to do running of ur bike in the evening and then see if it's still super hot or normal,
    And first oil change should help aswell a little.
    ftb7007's Avatar
    Apr 2016
    Peshawar
    45
    3 Post(s)
    Thanks all of you guys. Actually what happening is i drive it for 10-15kms daily & the heat is so intense that i can feel it near my feet. After 1 hr i touched the silencer it was almost cool but the engine was severely hot.
    post911's Avatar
    Jul 2012
    Other
    189
    3 Post(s)
    I had 3 cg 125 euro2
    And 1 deluxe in last 5 years,
    Deluxe was the only bike which lasted 2 years with me,
    And now I have ybr
    This yamaha machine is by far the most comfortable and equipped with all the required latest gadgets of today's riding requirements.
    If ur pocket allows u
    Then my friend u should go and check this bike out.
